Traded my 2019 Sierra 3500 in yesterday for the 2020 version. Definitely interested in the cameras. When I was at the dealership this morning to get a couple of things I forgot from my old truck, I asked about the invisible camera and a camera inside the trailer (we trailer horses, so an interior view of our horses would be great). Guys in parts didn't know, so he called the manager at the local GM parts depot who got my VIN and  looked it up. He called me back and said that they had the cameras in stock and I mentioned that I have a 49' long trailer and he said it would work with a bluetooth extender.
So, now I'm trying to figure out if the camera setup is wired or wireless. Seems to me that the OEM cameras are wired - did he have his parts or my truck mixed up with something else?
The quote for 2 cameras with install was $1310.
Yeah GM thinks they are made of gold. The aftermarket should have cheaper options soon.
Sent from my SM-A505U using Tapatalk
On 3/30/2020 at 10:50 PM, Cool J said:
GM was no help, but I was able to find a supplier for extension cables to swap the bumper plug with the bed plug at the following link within this forum. Copy and paste into your search engine.
https://www.gm-trucks.com/forums/topic/235530-help-w-relocating-camera-port-from-bumper-to-bed-for-5th-wheel/?do=findComment&comment=2388376
Did you consider/price an additional plug the same as the bumper and installing it in place of the one in the box instead of swapping?  I’m wondering how much one of the plugs is and just add it to the box. I may make some calls tomorrow if I ever get the wire fished all the way to the back of my RV....
I have a 45' long toy hauler. I understand at that length the camera will only work as a backup camera. My concern is I do not believe the supplied cable will be long enough to route the way I would like too. Does anyone know if there is any kind of extension cable available from anywhere?
First time poster, got some great tips here on how to mount the trailer camera so I figured I'd post pics of my install in case it helps others.
I have a 26' Travel Trailer so the cable length and hookups were perfect for my setup. Instead of drilling holes for the camera mount, I attached it to the camper with 3M super strength vehicle molding tape. I also placed the camera bracket upside down to avoid having the loop of cable out the top of the camera. I painted the cable white to try and blend it in a bit to the color of the camper. I also bought an extra Camco battery box to hold all of the slack cable at the front of the camper - I just drilled a couple holes on either side of the box to run the cable through. I used Cool J's tip to run the cable underneath through 1/2" non-metallic Liquidtight Flexible Conduit through some of the camper frame cutouts and I attached it in a couple spots with a some Line Clamps.
Took it on a trip over the holiday weekend and it all worked great - love having the rear view transparent trailer option.
Ok to help others that are setting up their cameras. I did in fact extend the camera cable 20 LF! I found that the truck side of the connector is hard to find at the best. So I disassembled the camera and found the camera used the same connector the bed plug uses that everyone got a 4 foot extension to move the plug into the bed from the bumper. I also did that. But my GN trailer is 48 feet and the 59 foot camera cable was short (I also planned slack in the truck bed). I contacted Derek in sales at Pasternack and we came up with a cable. Now the new extension cable is abut 3/16 inch thick and very susceptible to damages.  So you WILL have to sheath the cable for protection. Remember this is on the camera end of the cable routing. In my trailer I have a1/2 electrical EMT conduit which will protect the cable really well.
Here is a link to the photo's and the bottom of the photos shows the new camera cable and the camera. https://photos.app.goo.gl/d2UVb4djaqf3ashL9
If you have questions let me know and I'll try and help.
One thing to add is I used a Scotch 133 rubber vulcanizing tape 1 layer and 1 to 2 layers of Scotch 33+ tape to fill the void on the camera ball where the camera enters the plastic ball.
Chuck
Edited by Gecko50
Added rubber filler tape
Did the image end up being reversed or upside-down when you placed the camera bracket upside-down?
No, if you undo the screws on either side of the bracket, you can rotate the camera the other direction. One drawback is you won't be able to use the markings on the side of the bracket to line up the camera because the camera will be in a different position. I was able to eyeball the angle and it worked fine though.
Here's another idea for mounting & running your wires.  As I didn't want to drill holes in my rear wall, I mounted my camera to a piece of 3/4 × 1-1/2  aluminum channel and attached it to my to the ladder with stainless steel u-bolts. I then ran 3/4" PVC conduit under the trailer through the open tubing that the springs mount on for the entire length of the trailer. A wide 90 degree coupling then up the ladder. I pulled my wire before gluing that coupling to make it easier.
Folks,
I just received my 2500 Sierra that came with the camera.  I have a 5th wheel trailer but my truck did not come with the 5th wheel trailering package.  The camera jack is in the normal bumper pull wiring harness.  As I have the 5th wheel harness installed (there is already a space dedicated for it with a blank cover) shouldn't there be a port for the cameral to plug into?  I see on this thread several of you have 5th wheel travel trailers. I assume you don't have the camera plugged into the bumper but rather in the bed next to the 7 pin connector right?  If the latter, I need to order that part so it can be set up correctly. Any ideas?  Thanks in advance.
DSR
2021 2500  Sierra Denali "Black Diamond Edition" Duramax
On 11/6/2020 at 1:03 PM, DSR said:
Folks,
DSR
See this thread...
Thanks Chuck for the info and the pictures, I have a 38' toy hauler with the furrion camera, I like the camera but don't want the extra screen on the dash, I just took delivery of my 2020 3500,  will order the camera and extra cable next week and install.
Thanks a lot I had this done over that past week with my hitch install. They were very appreciative that I already had the cables and knew what to expect.  I'm now trying to figure out how to feed the camera conduit thru the pinbox box down to the undercarriage of my trailer. If anyone has any hacks on getting from the pinbox to where the propane or genset is I'm all ears. Thanks again. DSR
Chuck
Chuck
Your pictures have the answer to a lot cheaper solution!
I googled the # that I could read on the exposed camera that you have in one of your pictures and it comes up as: 'Parking Reverse Rear View Backup Camera For 2019 Chevrolet Equinox'
A lot cheaper: https://www.ebay.com/itm/23390514-Parking-Reverse-Rear-View-Backup-Camera-For-2019-Chevrolet-Equinox-/254413806610
With a couple of the cables that you sourced from Pasternack and I  should be able to fab an enclosure/mount with a little bit of design and 3-D printing
I'm gonna give it a shot
Thanks,
John
On 8/26/2020 at 3:27 AM, Londart2020 said:
How do you do the iNCommand feature? I have a Cougar TT with that system. Thanks.
Here is info from the iNCommand website: https://in-command.net/get-in-command/
  • Adrenaline by Coachmen – (Model Year 2019)
  • Alpine by Keystone – (Model Year 2019 to Current)
  • Big Horn by Lakota – (Model Year 2019 to Current)
  • Blaze’n by Pacific Coachworks – (Model year 2019 to Current)
  • Cougar by Keystone – (Model Year 2019 to Current)
  • Fuzion by Keystone – (Model Year 2019 to Current)
  • Lance  (Available on Select Models)
  • Luxe by RV Factory – (Model Years 2018 to Current)
  • Luxe Elite by RV Factory – (Model Years 2018 to Current)
  • Luxe Toy Hauler by RV Factory – (Model Years 2018 to Current)
  • Minnie Plus Fifth Wheel by Winnebago – (Model Year 2019)
  • Minnie Plus Travel Trailer by Winnebago – (Model Year 2019)
  • Montana Legacy by Keystone – (Model Year 2019 to Current)
  • Powerlite by Pacific Coachworks – (Model Year 2019 to Current)
  • Rage’n by Pacific Coachworks – (Model Year 2019 to Current)
  • Raptor by Keystone – (Model Year 2019 to Current)
  • Redwood  (Model Year 2019 to Current)
  • Sands by Spectrum – (Model Year 2019 to Current)
  • Sandsport by Pacific Coachworks – (Model Year 2019 to Current)
  • Voltage by Dutchmen – (Model Year 2019 to Current)
    TopBo
    TopBo
  • Who's Online   1 Member, 0 Anonymous, 1,028 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
