It appears that the new V807 Infotainment Update has started to rollout for downloading according to several users.
Thanks for the heads up. Any idea what changes are included in the new update?
This is my first new vehicle in a decade,  forgive the stupid question but how do we do the update,  do you have to go to the dealership?
You can get the update at the dealership, but I'd wait until it rolls out to your vehicle which can take weeks since there are few hundred thousand units. There is a Settings Icon which will lead you to an Update Icon that will initiate a download if the vehicle is permitted. It will also check at startup periodically if the Update option is checked in your settings. GM has 3 infotainment units also IOR, IOS and IOT which the IOS and IOT units will receive the update.
Edited by Rocz3cqg
  • Thanks 1
No idea so far.
14 minutes ago, Rocz3cqg said:
You can get the update at the dealership, but I'd wait until it rolls out to your vehicle which can take weeks since there are few hundred thousand units. There is a Settings Icon which will lead you to an Update Icon that will initiate a download if the vehicle is permitted. It will also check at startup periodically if the Update option is checked in your settings. GM has 3 infotainment units also IOR, IOS and IOT which the IOS and IOT units will receive the update. If you have a 8 inch screen, then you have a IOS or IOT.
Thank you!!!!!
There is an 8” version of the IOR infotainment. It’s standard on LT/RST and SLE/Elevation, and is not eligible for OTA updates.
Rather than going by screen size, just check if you have an SD slot above your USB outlets. Console-equipped trucks have the SD slot in the console, bench seat trucks have the SD slot on the dash‘s USB ports. If you have the SD slot, you can download updates. No SD slot means base infotainment and no OTA updates.
But as said above, it’s a staggered rollout so just keep checking or wait for the truck to tell you it’s ready.
  • Thanks 1
Thanks for clarifying.
Mine updated last evening.  So far I've noticed a quicker load time for user profile and the Spotify app.  Much faster.  I didn't notice any new apps added and I had to re-set up Market Place by accepting terms, etc.  Other than that, it seems like this maybe an "under the hood" update.
everytime i see this i'm reminded and annoyed that my expensive ass z71 RST doesn't have the update feature... With all the tech these days, the ability to not update your tech is ridiculous. I constantly have buggy connection and audio issues with carplay that I have no doubt would be solved with some patches.
My truck updated yesterday, was prompted to install when parking the truck. Definitely quicker and connects faster than previously (although the only issue I had before was bluetooth lag on startup).
Edited by Darth Potatoes
You might want to remind the dealership to check on updates for your radio when you are in for service.
The update hasn’t hit my truck yet, but I’m glad to see that one of the issues it addresses is the SD card error. I’ve gotten that a few times, where it says the card was removed and nav doesn’t work. Other threads say dealers were replacing either the card itself or the card reader. Maybe it was a software issue after all..??
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
