It appears that the new V807 Infotainment Update has started to rollout for downloading according to several users.
Thanks for the heads up. Any idea what changes are included in the new update?
This is my first new vehicle in a decade,  forgive the stupid question but how do we do the update,  do you have to go to the dealership?
You can get the update at the dealership, but I'd wait until it rolls out to your vehicle which can take weeks since there are few hundred thousand units. There is a Settings Icon which will lead you to an Update Icon that will initiate a download if the vehicle is permitted. It will also check at startup periodically if the Update option is checked in your settings. GM has 3 infotainment units also IOR, IOS and IOT which the IOS and IOT units will receive the update.
Edited by Rocz3cqg
No idea so far.
14 minutes ago, Rocz3cqg said:
You can get the update at the dealership, but I'd wait until it rolls out to your vehicle which can take weeks since there are few hundred thousand units. There is a Settings Icon which will lead you to an Update Icon that will initiate a download if the vehicle is permitted. It will also check at startup periodically if the Update option is checked in your settings. GM has 3 infotainment units also IOR, IOS and IOT which the IOS and IOT units will receive the update. If you have a 8 inch screen, then you have a IOS or IOT.
Thank you!!!!!
There is an 8” version of the IOR infotainment. It’s standard on LT/RST and SLE/Elevation, and is not eligible for OTA updates.
Rather than going by screen size, just check if you have an SD slot above your USB outlets. Console-equipped trucks have the SD slot in the console, bench seat trucks have the SD slot on the dash‘s USB ports. If you have the SD slot, you can download updates. No SD slot means base infotainment and no OTA updates.
But as said above, it’s a staggered rollout so just keep checking or wait for the truck to tell you it’s ready.
Thanks for clarifying.
Mine updated last evening.  So far I've noticed a quicker load time for user profile and the Spotify app.  Much faster.  I didn't notice any new apps added and I had to re-set up Market Place by accepting terms, etc.  Other than that, it seems like this maybe an "under the hood" update.
everytime i see this i'm reminded and annoyed that my expensive ass z71 RST doesn't have the update feature... With all the tech these days, the ability to not update your tech is ridiculous. I constantly have buggy connection and audio issues with carplay that I have no doubt would be solved with some patches.
My truck updated yesterday, was prompted to install when parking the truck. Definitely quicker and connects faster than previously (although the only issue I had before was bluetooth lag on startup).
Edited by Darth Potatoes
You might want to remind the dealership to check on updates for your radio when you are in for service.
The update hasn’t hit my truck yet, but I’m glad to see that one of the issues it addresses is the SD card error. I’ve gotten that a few times, where it says the card was removed and nav doesn’t work. Other threads say dealers were replacing either the card itself or the card reader. Maybe it was a software issue after all..??
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 649 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
