When are you planning on doing it? WE NEED TO KNOW!!!!!!!!!!!!!!!! [emoji3]
I have some hay I need to mow, rake and bale first...but if it rains, I'll pull it into the shop and work on it!
stand pipe is part of the re-fill proceedure on the camaro. I would just zip it off with a dremel tool, unless its used to suppor the camaro trans filter, then i would leave it and drill a few drain holes around it's base
you did order the taller camaro filter right?
Edited by flyingfool
  • Haha 1
Oh, just one more thing! About that filter.......(Columbo) :)
I thought the same thing, cut that stand pipe off. Just be sure there are still some threads left in the bung.
So how do you get the fluid out of the lower part of the pan? Just asking. (That plug isn't really a 'drain')
That was my first thought when I unboxed it as well. Technically, it is a drain plug. But not one that will allow you to drain the pan completely due to its location. I'm considering just getting a weld on drain plug and having my buddy at the local welding shop put it in at the lower end of the pan so it'll remove as much of the oil as possible.
The top of that stand pipe is the FULL level.
Standard pan. Wasn't too sure I wanted to try a deep pan or if it would fit.
also wondering if there is a rubber gasket behind that drain bolt from GM.?
i would of ordered the deep pan instead.. anyways I look forward to seeing what you come up with.
deep pan is more for heat resistance capacity, not for ease of draining.... but I just disconnect the upper trans cooler line , and pump the fluid from this line  into a bucket, then pull pan and filter.  if your hard core, you'll drill and tap the torque converter for a pipe plug for more drainage
Get a might vac fluid extractor, best thing ever for doing oil changes or fluid exchanges.
I can suck a hot transmission pan "dry" in a few minutes. I've done the last 3 oil changes on some of the family cars in the garage without even taking the drain plug out.
Which model/version did you get?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
