3 minutes ago, The Zip said:
LA county daily covid brief reported in the past month, hospitalizations for the age group from 0 to 17 increased 50%, the age group from 65+ decreased 12%.  That's a flip, 65+ has been in the crosshairs for a while.
It’s easy to get to a 50% increase in an age group where numbers are so low to begin with. If there’s two 15 year olds in the hospital, and a third is added...well that’s a 50% increase without changing the actual number all that much.
Granted that’s an exaggeration but a 50% increase may or may not be a meaningful amount or trend. Presumably since there are no deaths in California in that age group, the number of hospitalizations must also be exceedingly low.
In other words, I bet a 12% decrease in 65+ amounts to more people than a 50% increase 0-17.
My brother in law has to be tested regularly for his job and Monday morning he tested positive on the rapid test. Our whole family including my daughter, son in law and two grand daughters spent the day on the lake. We also spent the night and made breakfast in the morning before returning home. Wife and I are scheduled for testing tomorrow afternoon. Brother in law has no symptoms whatsoever.
Curious about other areas plans for Fall School.  Here, we have 3 major school districts and all 3 have different plans.
1.  2 days seated school, 3 days virtual OR 5 days virtual - District 1
2.  5 Days seated, mask required OR 5 days virtual - District 2
3.  5 Days seated, no mask requirement (but encouraged) OR 5 days virtual - District 3
We are not considered a hot spot area of MO BTW.
They are “starting out” with E-Learning here, the county I reside in just announced it today. Of course by “starting out”, we can assume they mean at least the rest of the year, if not much longer. Since they are clearly not following the science (one of their favorite terms), anything goes and the goal will keep changing.
All of this comes after many of the districts passed huge referendums back in the fall. Unfortunately you don’t need those multi-million dollar renovations for empty buildings. Hell, you don’t even need the buildings. Instead of pissing money away on ineffective E-learning “upgrades”, give the people our tax dollars back and let us use it for private schools that will actually teach kids. Because giving a 6 year old an iPad and expecting them to learn anything is outrageous.
Any time wasted with this is time that will never be recovered. It’s not a golf tournament or baseball season that we can shorten or continue to postpone without consequence.
These kids aren’t getting the proper education. Look at California where they made passing the bar easier. These are our future doctors and lawyers. Scary
Based on what I saw at both games, all the players will become sick and die. :jester: Players weren't following the rules set forth by MLB. Chewing, spitting, licking fingers. Mound meetings were closer than six feet with no masks. Batter, catcher umpire closer than six feet.
Good experiment
Don't know how you play football with all the rules. Lineman are blowing in each others face every play
Edited by txab
He had to keep the ball at least 6 feet away from the plate. Everyone knows the new rules.
Based on what I saw at both games, all the players will become sick and die. Players weren't following the rules set forth by MLB. Chewing, spitting, licking fingers. Mound meetings were closer than six feet with no masks. Batter, catcher umpire closer than six feet.
Good experiment
Been playing since the beginning of June here. I may have licked my fingers a time or two or a few dozen times throwing BP. The worst part of it all is we can’t have sunflower seeds [emoji26]
Ryan B.
2 hours ago, RyanbabZ71 said:
Been playing since the beginning of June here. I may have licked my fingers a time or two or a few dozen times throwing BP. The worst part of it all is we can’t have sunflower seeds emoji26.png
Ryan B.
We had one coach that spread it around to a couple of other adults. Kids have all been fine
2 consecutive 4 day periods adding a million world wide cases. Yea, a million cases every four days.
Skip school for a year. So what you graduate at 19. What do they think would happen? Forget everything they learned?
 (Isn't really about kids, is it?)
This topic is now closed to further replies.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
