Been getting this error when starting my truck now: “please confirm password to continue using connected services”. What password would that be?  Doesn’t seem to take my WiFi or profile password.
Mine did this last week,   if you tap inside the box, not on the X,  it will take you to a screen and ask you if your password is correct and then the message will disappear.
I don't know why it happened,  I guess it had something to do with an update of some kind?‍♂️
Didn't GM give wifi access for the month of April?  Covid-19 related?  I'm guessing it's gone now, and this is why we are getting the message?  I've been getting it too, but I haven't done any recent update.
I was getting the same message, and It would not accept my password until today.
I did login to the My Chevrolet website, which may, or may not have been related to finally getting it to work.
Thanks for the replies everyone. I logged into mygmc website and I was promoted that my password was no longer valid, so had to reset password. Did a reset and the new password worked in the truck. All good now.
  • 9 months later...
Minor old thread resurrection.
I get that message all the time, especially when a trailer is attached.  Goes to the towing screen and asks for a password.  I have never set a password for anything, nor did I get any phone apps or sign up with onstar.  (nor do I want to)  How do I make it stop?
I've tried every password I have and even reset my password for the MYGMC app and nothing works. Onstar even tried to update the software and failed to clear it. I've had this since March 2020 and its pretty annoying. Has anyone found other ways to clear it?
Mine does this as well about once every 2 months... I put my password for the MyChevy App into it and it goes away. Not sure why it prompts all the time but that stops it for a couple of months.
  • 3 months later...
I think it could be related to the WiFi Hotspot? Mine started doing it again yesterday. I tried to turn off in my.chevrolet.com but said it cannot connect to my truck at this time. Funny, it connected at first to download the hotspot name and password.
  • 7 months later...
Am about ready to drive my new truck through the dealers front window. Very distracting when pulling a travel trailer, the navigator screen flips to password required. Have to take my eyes of the road to go back to navigator screen. Every darn 15 minutes on a 12 hour trip. CRAP
I have this same problem.  I've tried everything password I can think I would have used and none work.  So while I'm driving down the road with a 30', 7000lbs in tow they want me to enter a password?  Maybe next time I'll call and wait on the phone for them to help me while I'm driving.
Thought I'd share in case it might help others. Like other posts, I've had this message popping up and I've tried known & working GM/Chevy passwords and PINs, but they wouldn't take. I should have noticed this, but the password prompt pops up when using my wife's User/Profile. So for those that swear they're using the correct password (and have multiple users), make sure you're under the right profile in Users.
  • 8 months later...
This happens for my spouse who uses profile 2. He has never set any passwords. Should he set one for this to stop? No help from the dealer.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
