I would like to paint my exhaust tips black and have been reading up on this.  At this time I don't really want to get into taking exhaust tips off.  Do you think high temp grill paint or engine paint would work?
High temp paint should work but since they are chrome, you need a primer that works on chrome.
Otherwise the paint will peal from the chrome. But you can always repaint as needed.
Taking them off is easy. I replaced mine with powder coated ones.
Looks so much better black.
Good luck with painting.
They aren’t hard to remove. I had my 10 yr old son do most of the work. We used it as a “life skills” class for eLearning [emoji23] either way the black looks better than chrome. Imm no purchased powder coated ones
Ryan B.
Ryan B.
I'm more in love with the ZL1 in the background than the black exhaust tips, and i really love the black exhaust tips.
It’s only an SS with the 1LE pkg
Ryan B.
Ryan B.
That 1LE tricked me. Still love the car though. If you're not driving it sideways you're driving it wrong.
With these Goodyear super car 3s it’s tough to get it sideways it drives so nice and is planted to the road even with everything turned off
Ryan B.
Ryan B.
If you let me behind the wheel I'll see what I can do to break her loose. I promise to play rough, lol. [emoji39]
I've been doing some digging on black exhaust cutouts in the rear bumper. I ran into a dead end on GMPartsDirect. Turns out GM does make some. I found them on a Midnight Edition Silverado Trail Boss. I wasn't able to grab its VIN, so I went to Chevy.com and used the build & price tool. When I clicked on the Midnight Edition package I noticed the truck's exhaust cutouts turned black. I then finished the build and clicked on the button that allows you to search available inventory near the default zip code GM's website input. I was able to find a midnight edition Silverado, and wrote down its VIN number. I then took the VIN number to my local dealer to find the part number. They gave me the part numbers, but told me the parts are on backorder. Nobody near to the dealer's search area has them. I then jumped on to GMPartsDirect on my cell phone and searched the part numbers. They are below. The result revealed these are for the Carbon Pro Edition GMC Sierra. I checked the compatibility for the Silverado, but GMPD said they aren't compatible. I get it. Go look for these without a part number and no VIN and all GM sources say these don't exist. IIRC, the price for the black exhaust cutouts are about $10 more each than the chrome ones on GMPD. I want these for my Northsky Blue Trail Boss, so I'll dig a bit further into this to find out how long the backorder is. I'm trying to eliminate all chrome from the exterior of my truck. Hopefully this helps somebody out.
Left Side: 84644535
Right Side: 84644536
Left Side: 84644535
Any luck on these?
Any luck on these?
I haven't looked further into this yet. I moved across the country. When I posted that I was living near Virginia Beach, VA. I'm now in San Diego, CA, and drove the new truck the entire way. Just got the keys to my house on Friday, and my furniture arrives Monday. It's been a crazy time for me. I'm sorry. Hopefully I can get back to this soon. I want to eliminate all the chrome on my truck badly, but this cross country move was something I needed to get through before I could finish my truck.
11 minutes ago, DarkSky20 said:
Found these on eBay. https://ebay.com/usr/partsfynder. Just bought the matte black set. Says I should receive them by Sept. 30th
Yeah I saw those too, I got a guy who would PC them for me for $60 bucks. Just looks like a PITA to remove them and really don’t want to snap any plastic on a brand new truck.
I might dip mine first and see how that goes. Plus not sure what color I want to go with yet as my bumper is black and truck is the Satin Steel....
Where did u get the powder coated ones from or did u do it yourself?
    • Anyone have any info about backorder time? It's classic 4th of July hot here in ohio.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
