has anyone else had trouble with there truck going sideways on gravel roads in pot holes or washboard ????    is there a fix for this that is not too expensive ????   new here so Thank you for your Time ....
I never had but a friend has. Had to replace shocks. I would look at the Bilsteins.
Sent from my Pixel XL using Tapatalk
Are you are running truck 'unloaded' and have factory tire sizes at the pressures on the door sticker?
If so try running reduced tire pressure - its a free trial.
Washboard road has always been a issue in a pickup -- especially unloaded and at speed.
Suspension adjustment -- by setting tire pressure match current loading -- can help.
I have a 2019 Sierra SLT 4x4, and I lived with the crappy ride for almost a year. I noticed the same thing, it would go sideways when going over bumps, lose rear traction easily, etc. I installed new Bilsteins on the rear about three weeks ago - best $200 I ever spent. The ride is much improved on all less than perfect surfaces.
As others have said, loading up the rear with several hundred pounds and/or reducing tire pressure can help (I tried both) but neither helps nearly as much as getting the junk factory rear shocks out and replacing with good ones.
A LOT of us have this issue. It's very well-known.
Adjust your tire pressures down some, it helps. The shocks will also get better as you put mileage on them.
Best solution, though, is to replace them with either Bilstein (not out yet) or Eibachs.
I just put Bilstein 5100s on the rear of mine today. I haven't driven it yet.
There is now a 5100 for the front but no one has it yet. Part # for the front will be Part Number: 24-293297. The rear is Part Number: 24-293471.
I've driven a truck on washboard dirt roads since before I was legally old enough to do so and every one of them to some extent will do that, and the longer the wheelbase the move pronounced the effect. Trucks are made to haul stuff and when the bed has nothing in it they will tend to get a little "squirrelly", they certainly make shocks that will help but as mentioned a cheap fix it to put something in the bed. Doesnt have to be much...back in my wilder days even a igloo full of ice and beer makes a big difference lol.
I had the same problem on my F150. Bilstein 4600’s fixed it. Can’t wait until they have the 4600’s for the new Sierra. Hate that feeling.
On 7/15/2020 at 7:48 AM, Barry Hartling said:
Thanks Guys for all the help.. going to see if the dealer will help  Thanks again .....
They won't be of any help. You need new shocks to get the more planted ride you're wanting (and should come OEM off the lot!)
The other day I was following Mrs. Econometrics home in her minivan, she was driving my RST. I was watching the rear suspension on my RST... wow... it was just bouncing up and down like a loose noodle. Someone with a TB was driving in front of us, and I honestly didn't see the same play in the rear end. Then a GMT900 1500 CC drive along side my RST for about a mile... same thing. Rear axle just did not look as bouncy. Made me realize how badly I need to get rid of these Rancho twin-tubes.
The key question here is: why weren't you making Mrs. Econometrics drive the minivan?
  • Haha 1
? We had $5500 of (warrantied, thank God!) work done on the suspension, so I needed to make sure the dealer got it right. ?
Which make?
That just sounds more like something that would be happening in the minivan.....
  • Haha 1
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
