11 hours ago, MaverickZ71 said:
AC Delco PF63E
AC Delco Ultraguard Gold UPF63R
Wix 10255
Wix 10255XP
NAPA Gold 100255 (same as Wix above)
NAPA Platinum 4100255 (same as Wix XP above)
Bosch 3502
K&N Gold HP2011
Royal Purple 20-500
Mobil1 M1-212A
Fram Titanium FS10575
Purolator One PL22500
Purolator Boss PBL22500
Baldwin B7449
There.  I did your research for you, even though you can look them up just as easily as the rest of us.
Personally, I quit AC Delco when they invented the "E-core" filters.  I use Wix now and have never had one leak yet.  But I install my own in the driveway from the Kamala position.  (Making Oil Changes Great Again!)  :D
You have superior internet skills than myself haha! Thanks for the list.
Been using NAPA aka WIX oil, fuel, and air filters for many years, never any issues.
Okay, for how many miles?
Something I've noticed, and I'm not picking on you Ryan, is that claims are made with either, absence of reference or a reference where the bar is so low a slug could jump it.
Saying I've use XYZ for years without issue but not saying 50 K is the longest you've ever owned a vehicle doesn't inspire confidence. See what I'm saying?
My uncle ran a flat-head Ford a million miles without a filter or a rebuild, but he also changed his SA-SJ oil every 500 miles.
Statements of excellence need CONTEXT.
  • 7 months later...
  • 4 weeks later...
I'm not a fan of the e-core AC Delco filters.  It it has an E at the end of the filter#, I'm not using it.  I'll buy a WIX or Mobil 1 Filter.
  • 1 month later...
Looks like for convenience, I'll be buying the WIX WL10255XP locally, but in 5k miles will try the Amsoil filter.
Thread reminds me when I had my 2003 GMC SD (6.0L), bought in '05 and recently sold. When I did that truck's oil/filter change, the OE filter size I thought was as small as the V4 and V6 Toyotas I owned prior.  Soon after, when I learned about the larger filter replacement, the truck ran much smoother (with full synthetic oil). My oil change/filter change interval was ~5k and sold that truck with 165k. I did a diagnostic on the engine shortly before selling, as it was the last thing I hadn't really worked on, besides spark plug/wire change, LS6 valley pan exchange and CAI. The engine internals were happily still within spec, with no leaks and that's with putting the truck through it's paces of towing and moderate/aggressive driving styles.
Interested to see how this 6.2L compares.
  • 1 month later...
I only run the NAPA Platinum 4100255 on my 6.2.  Not a fan of the AC Delco e-core filters.
On 8/12/2020 at 8:00 PM, EricTheRed said:
Here’s the one the dealership gave me and neither of the part numbers match up to anything I’ve seen online... weird
This (part #12707246) is the new PF63 that replaces the PF63E. Your manual probably calls for part # 12690385-PF63E but as you can see at the below site that filter has been superseded by the 12707246-PF63. Just make sure it's the PF63 with the proper part # (as pictured above) if you're looking for the PF63E.
https://gmserviceinsights.com/new-acdelco-oil-filters-deliver-enhanced-performance/
This has caused a lot of confusion because ACDELCO/GM decided to rename the filter from the PF63E. Therefore it's important to have the correct part number for your PF63 application.
This post is not directed at/to the OP. I just chose this post because use it's an excellent picture of the new filter part number. This is just information directed to, and for the benefit of, the general forum population.
JMHO
No expertise implied or expressed
Double Post
Edited by RWTJR
Double Post
NAPA/WIX filters are 2/20-6/20 (Beta Ratio) or 50% efficient at 6 micron and 95% efficient at 20 micron
Purolator Pure One PL series is 95% efficient at 8 micron and 50% efficient under 5 micron.
The standard GM wear test presented to the SAE says we need to compare at a Beta Ratio of 75 or 98.7 %. Problem is no one wants to play.
Instead they wish to peg the results to a micron rating which is 20 micron then just give the percent efficient at that size.
In that regard the the WIX/NAPA is again 95% at said 20 micron and the Purolator Pure is 99.9% at 20 micron. Yea, a Beat ratio of 1,000! They publish lower. :dunno:
FRAM ULTRA GUARD (only), Royal Purple along with the Purolator Pure One are all about equal.
Filters like the Mobil 1 and Purolator BOSS are dog and cat catchers even at 30 micron. They give up efficiency for duration. Bad Trade Dumb Bear.
WIX/NAPA fall in between.
I get conflicting information on AMSOIL filters. One source says equal to the Royal Purple/Purolator group another says just a smidgen behind but really close.
K&N brags on it's inefficiency up playing lower flow restriction. About on par with K&P stainless mesh cleanable filters.
For whatever reasons there are people like to open filters and debate construction. Me....I like my filters to filter. I've never had ANY filter leak or structurally fail that was properly installed and used.
28 minutes ago, Lakermadness said:
PF63E has a higher pressure relief rating of 22 lbs if I remember correctly.
PF63 was 12 lbs.
Key word WAS. New stock PF63 22 psi has replaced current stock PF63E 22 psi and 'old stock' PF63 12 psi. Leave it to GM to create confusion where none existed before. 😡
Everyone else just used a completely different part number. 😱 Now there's an idea, eh?
So I guess no way to tell if you get an old stock or new stock filter.....LOL
Actually the packaging changed somewhat.  New "Global Parts Branding" boxes
Auto Parts: Oil, Fuel, Transmission, Engine and Cabin Air Filters | ACDelco
Old Boxes
Don't use them myself.
On 8/12/2020 at 3:27 PM, Grumpy Bear said:
There, the list all cleaned up. :crackup:
u mean the h0rizont@l kamel-t0 Position right!!!!    ").
    • And to top it off finally.......................these small GM LS engines are designed to SPIN!!!!!  Why choke them down to just off idle for cruising.  Why/how the "bean counters" have influenced the "engineering department" at GM is beyond me.   They took a solid platform of an engine and turned into a joke in OEM form!!!
    • Atlas,   Then following your logic we can't believe any story that the MSM produces? I mean it's documented they heavily donate to Democrat candidates. Vote Democrat in high percentages. Many MSM talents are married to Democrat politicians, Gov. employees. That goes for on-air and off, personalities and reporters. So they would all be biased and nothing they produce is to be believed in your mind?   Again the article simply was about ways AI can be used for pricing products. Nothing discounted current situations as a factor.    Again keep looking through your left/right lenses. I don't live my life that way.   And as a heads up this thread will be cleaned up again as much of this is off topic and is receiving
    • Yes, and only a couple years before delivery. 🙄
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
