Title says it all! Tried searching the many tonneau cover threads but there is no easy answer it seems. I am gathering that there is NO soft roll up tonneau that works with the power tailgate. In some reviews, people have 'loosened' something up and jimmy rigged it perhaps to allow the tailgate to work. If thats the case I am thinking of just getting a cheaper cover. Why spend more if it does not work with the tailgate?
I am looking at the TYGER T1 (cheapest out there) or the Gator SR1. Thought I would check to see if anyone has found a product that works with the power tailgate out of the box?
Truxedo Lo Pro
Affordable, easy install, no leaks (minor seepage) and zero issues with power up/down tailgate on my 19 LTZ
1 hour ago, apollo177 said:
So i only have the power down tailgate on my LT trailboss, but I got the gator ETX soft top roll up and it closes shut very easy when i raise the tailgate.
https://www.amazon.com/dp/B07J2T7DZC/ref=cm_sw_r_cp_apa_i_LTxpFb6BY6T2V
So far its been pretty good, it doesn't rain much on my side of oahu but when it has, it keeps the bed dry. 9e3d4c4bcf63bb141241cb91b1a021e5.jpg96cd0d1416ac4e95b25cc0cbd99dd82c.jpg6f573d2c29fe131206912218abc99f19.jpg
Sent from my SM-G973U1 using Tapatalk
Thanks! I think I have the same. Sorry when I said 'power tailgate" I only meant the auto 'down/open' button from the FOB or the clicker in the center console. Thats what I have - it is not powered back up closed.
So when you click the FOB to open the tailgate, it will fold open no problem? Thats what I am looking for. I have read many of them 'click' to de-latch but get caught and won't open.
Yeah it opens perfect, I have never experienced issues opening when the soft top is fully extended, either with the fob or the center console. For a little over 200, its a good cover so far.
How has the Gator EFX been working for you since you last posted here.. I just got a 2021 RST and looking to get a soft roll up... I put an Access Lorado on my 2014 LTZ and loved it but it's now like $500...
Thanks,
Dan
Edited by Mcarlo24
Not what you're asking about, but with RetraxMx (the plastic slat one, manual roll) the multipro gate will open when the fob button (or dash button, or tailgate button) is pushed the tailgate fully opens.
One of the reasons I went to this cover (instead of the hard folding type I had been using) was because the cover doesn't have to be lifted when opening or closing the tailgate.
I have the same gator low profile and when I installed it I did set it a bit low and so I have to pull the gate down when opening and shut it with a bit of force. But it's not the covers fault, I just wanted it to sit as low as possible. My Dad has the same truck and cover, just finished it and installed it the right way and his opens with the keyfob no issues. It's all in how you install it. Nice cover for just over $200.
On 8/19/2020 at 2:33 PM, vancealot29 said:
Truxedo Lo Pro
I have a Truxedo LoPro on my High Country and it works perfect.
I have a Access Roll up on my LTZ and it don't let the gate open itself.
I have an Undercover Ultraflex hard trifold and it lets the tailgate work like normal, I don’t have to lift the cover.
I just put a Lund Genesis Elite on a coworker's truck. Works great with the power tailgate.
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
