Just ordered my pedal monster and I dash gauge for my 2020 5.3 rst. I’ll keep you guys posted on thoughts. The product is new and seems safer then the pedal commander. Anyone with experience with banks as a company or their products?
Looks Nice, I like the Pod too but it's a bit pricey!
I have one and love it. You can control it from the idash or from an app on your phone (uses bluetooth to connect to phone). Nice thing about it is't powered from the OBD port, not the 5v from the pedal. If you pull the power the pedal return to stock.
I had a pedal commander on a previous Chev and it caused codes due to taking power from the 5v to the pedal. I think it was causing the 5v to drop below a certain voltage causing the codes.
Jay
I did some research on this one, looks like its much better than the others out there. If you watch the video on their site, it explains the 5v power issues and the danger it causes.
I will most likely be purchasing this in the future.
Would you recommend getting it with the dash gage or is it easy enough to control from your phone?
I got the gauge with it. If nothing else I can use it to check and clear codes if I ever throw any. Only thing I wish banks would add would be a way to control auto stop. I see other products can do it solely through the obd port.
Same question from me.  What are the pros to the gauge that make it worthy of 2x the price of the standalone unit?
I am going to be getting one very soon, Banks makes GREAT stuff.  You can tell they engineered this thing right, is well thought out.  I will not be getting the gauge or pod...I mean, after the first day or two of playing with it, you won't touch it again!  But, I know a lot of guys like all of the gadgets and sticking stuff all over the truck, so to each their own.  I like keeping the interior clean and uncluttered, will just use the phone app to set it up and forget it.  Was happily surprised that the price was in-line with the competition, and it seems is a higher quality design.
I just placed my order for the pedal monster yesterday.  Not a fan of the hesitation when pushing the gas pedal...  Will report back once I receive it and installed.
  • 1 month later...
The owner of Banks is an OCD mofo, and anything that they make has been thought out and engineered to the hilt.  I would trust anything that they make without question.
Anyone here have updates on how their experience is going with this unit?
Install was super easy.  I have been very satisfied with the unit and I forget it is there most of the time.  For the first few days, I played with the settings and finally settled on the best feel for me.  No regrets.
  • 9 months later...
What is the difference between the Banks Pedal Monster and the Pulsar LT for a 6.2 2021 Silverado? I have heard good things on both.
James, Jay from Banks here. Both units are indeed similar. The biggest difference in the units is the PedalMonster's safety features, namely Reverse Safety. This function sets you back to stock throttle position when you're in reverse. This helps you from jack-knifing your trailer when backing up, or submerging your truck when backing in the boat at the launch ramp. Pulsar also does not have Active Safety bypass. If PedalMonster detects an issue, either internal or external, it's normally-closed relays latch shut, returning you to stock throttle sensitivity. Both of these safety features are patented.
I wonder how using both the PedalMonster and Pulsar LT would function?  PedalMonster a pedal/throttle sensitivity booster and the Pulsar a tuner type device?
  • 4 weeks later...
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, they can remotely disable the device. B) Make sure it's paid off. If they still owe money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
