My free oil changes are used up.  I'm not new at this as  I've been changing oil for 45 years. In the 70's it was also costumer cars.  Here is what I'm talking about. I drain a warmed up block for a good 10 minutes, change the oil filter. I even checked for a possible front sump drain in the pan. Didn't see one.  I then add the called for 8 quarts start it, check under for leaks then shut it off.  The damn oil is reading way high on the stick.   As I'm pouring the old oil in the empty jugs it measures up to about 6 quarts (and it was not reading low prior to the oil change) .  Can anyone smarter than myself explain this to me?  Thanks.
Are you sure the dealer was putting 8 quarts in?
Any time I have them change oil, I always confirm with them that they're putting 8 quarts in of 20w synthetic.
When you say "way high" on the dipstick, how high is way high?
There will be some oil in the oil cooler that won't come out with an oil change, but that's alright. The owner's manuals say to add 8.5 quarts, which would cause a high reading on the stick. It won't hurt anything but they put out a bulletin that says it's ok to just use 8.
Sent from my SM-J810F using Tapatalk
I can't find any of my receipts to check. I'm positive it's not a 4.3 (v6). I drained two quarts out and it still reads about a 1/2 inch high. Before that it would be about an inch plus high on the stick.  I guess it's possible I used up 2 quarts in 4000 miles! Sure as hell hope not though.  Truck only has 33,000 miles.
You need a shorter dipstick. Check it when its cold (don't start it), it should be the right length then.
Edited by M1ck3y
The stock air box usually has a sticker on it that says the engines displacement. Or just count how many spark plugs wires you got.
I really dislike these new plug style dipsticks. I get the best read in the morning before the first start after everything has cooled, it's thick and the tube isn't coated. Just pull and read. The one in the wife's GMC was so smooth it shed oil so I sanded it with some 320 WD to make it easier to read. Everything  I have (3) that has this style of stick reads high.
I have always checked my oil after it sits overnight.
3 minutes ago, supercab78 said:
I guess I'll  split the difference and run 7 qts. and keep a good eye on it for now.
Yeah, that's not a good idea. But its your truck ?
:crazy:
 Put in the 8 quarts, let it sit overnight then check it. Use this as a reference. Doesn't matter if it's shows overfilled it has the required amount of oil.
Whats confusing is you didn't seem to have this problem when the dealer was doing oil changes.
Dealers in my area will always put in 8 litres.  Do it myself now, and it reads accurate. I think their reasoning was that it somehow stops cold start lift tick.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
