I've read/heard a couple of things about people saying they had trouble with aftermarket converters but when I ask them what they didn't like, what brand, what problems.....I get ghosted.
I have been considering doing a 3000-3200 stall anyway but now it looks like I'll have to replace it if changing the fluid doesn't help stop the shudder. (I've had this work many times in the past so it's where I will start)
I've had stalls in the past, I'm just really needing any helpful info on what people have tried and what they did and did not like stalling one of these trucks with the 6L80
Thank you all in advance for any help.
camaro zl1 is $350 2200-2500 stall
i think circD is close to $900
Edited by flyingfool
  • 1 month later...
Stall speed is highly dependent on input torque. What stalls to 2200-2500 on a ZL1 that has 650 lb ft of tq wouldn't stall anywhere near that behind an NA L83.
Just warning you that it might be difficult to control any aftermarket converter with the limited access to the GM TCM algorithms. Read through this thread over on HPT: https://forum.hptuners.com/showthread.php?65233-6l80-TCC-LINE-PRESSURE-ISSUE-CIRCLE-D-3000-HP
I think constantly pulse like that stock?
I know on my truck right before I had the trans flush done the pulse was audible and followed the rise and fall of the rpm fluctuations. Now, maybe 5000 kms after the flush the truck is still smoothish with no rpm fluctuations, but the I'm definitely getting a constant up and down exhaust note in some situations.
I was considering dropping the 1500 cdn and getting a tune that included the trans. But now it sounds like with hp tuners you can't really correct this?
I'm running  the cts-v tq converter on a built 6L80. Feels almost stock. Feels kinda sluggish at low speeds, especially when cold. Shifts are crisper. Didn't even need a trans tune. No codes. Since I just crested 100k miles, going to start massing parts for a top end rebuild (cam, heads, L86 IM/TB).
isn't the CTS-V and ZL1 the same?   Good to know it works without a tune, i'm sure it will get better with corrected programming. i would down load the zl1 or cts trans file and  anylize the stock parameters and  compare that to your trucks file.  and try and mimic GM's tune for that set up
keep an eye on your trans temp. where does it run after the swap?
There was a specific reason the CTS-V from a specific year group was recommended over the ZL-1. I believe their stalls are identical, had something to do with mounting. I don't recall the details. Shop that did the work on trans and converter (my converter failed at 80k, all stock setup but I towed a heavy trailer often) has a world record holding C7 so I'm gonna go with their recommendation.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
