1 hour ago, L8T said:
Eventually we will see more gears as an option at least behind the 6.6 gas but if won’t be an Allison. The internals of that trans are so much heavier that it would be counter productive as far as fuel economy and wheel hp are concerned. Even if it was an 8 speed it would be better than what’s in it now IMO. I’d be happy with Ford’s 10 speed in it.
We have two F-550’s at work with the 7.3 gas and 10 speed. These trucks are touching 10k plus with service bodies and the 10 speed makes them feel like they have more power than the v-10 6 speed they replaced even though it isn’t much higher in the hp and tq dept. No issues with the trans but the engine is junk. It’s super picky with fuel quality where the v-10 would drink anything, constantly eats plug wires, we’ve blown out several spark plugs, and had multiple injectors changed already in 20000 combined miles. I wouldn’t recommend the ford till they get it sorted.
GM and Ford joint ventured the 10 speed units.  GM would use their 10L90 that's behind the Camaro ZL1 but with any truck related changes if they do it.
On 11/18/2020 at 10:02 AM, newdude said:
Sure it went to 3.42 but it gained 4 gears.  1st gear in the 10L1000 is 4.54:1 vs. 3.10:1 in the Allison 1000.  The 10L/3.42 gear multiplication in 1st through 8th gears is higher than the Allison/3.73 combo is 1st through 5th.  Could they put 3.73 in it?  Sure.  Would it be necessary?  No.  See 36,000lbs max tow rating.
The 6.6 gas is the one that got neutered here.  GM even got rid of the 3.73 on 2015-2019 trucks for a reason with the 6.0/6A.  It was the better pairing.  2007-2014 trucks with 3.73 gears on average saw a 3500-4000lbs tow rating loss over the 4.10 trucks.  GM went backwards on the 6.6 with 3.73 and 6A.  Needs either to go back to 4.10 or they just man up and do the 10L90 and leave the 3.73.  I still think that the joint venture had something to do with it that's why Ford got to do the gas with 10 speed HD trucks first.
Heck ford is now sticking the 10A behind their 3.3L V6  Base truck F150 ..If you ask me , its GM not wanting to spend more money . What else could the reason ?
  • 2 months later...
You will never see the Allison 10 speed behind the gas 6.6. It’s heavy internals would rob way too much torque and hp and it would kill fuel economy. A lighter 8 to 10 speed is what is needed here.
The only complaint I have with the Ford 10 speed is that the first three gears are too far apart and the shift strategy sucks. It’s better than the 6L90’s but I find it’s really busy on the highway and a dog down low if you have a heavy load on.
Edited by L8T
I fear all of these discussions will be moot points within the next decade.  GM's mandate to be 100% EV in all cars, and light duty trucks by 2035 will probably create a lame duck 4-5 year period for gas and diesel while they develop electric motors for the HDs.  With the torque curve of EVs, they will probably be going to CVTs, who knows. I love my Duramax trucks, and have for 18 years.  Going to hate to see them killed off.
GM is still investigating billions in next generation powertrains for future ICE vehicles.   ICE is still going to be a major player for a while.
#iworkforGM
#iworkforGM
GM specifically says 100% of passenger vehicles and light trucks will be BEV's by 2035, but that sounds to me that large pickups and commercial truck will be exceptions.  That having been said, I expect that eventually battery or hydrogen fuel cells will power those vehicles but it's probably further in the future.
BTW, I hope you mean 'investing', not 'investigating'!
Edited by C/K Man
They have that transmission already.  The 10L90.  Which is the one everyone wants them to put in there.
There has to be a reason they didn’t do it. Even as an option. Maybe the converter or trans as a whole can’t handle the hp/tq that the heavier truck would demand-especially towing as compared to being in a light Camaro.  The 10L is rated for 650 hp and tq but maybe it can’t take it for the duty cycle required in a truck application.
The first 4 gears are lower than the 10A, but the next 6 are very close or the same so it would work well in that regard.
I don’t think anyone is expecting to use the 10L90, but the design is there because the 10L90 exists. Just like the F-150 uses the 10R80 and the super duty uses the 10R140. Or the Ranger T6 using the 6R80 while the F-750 with 50,000lb GCWR uses the 6R140. Since they developed the 10 speed with Ford, I would expect GM to be capable of adapting it to a HD truck just like Ford was.
A lot of guys say the ten speeds are hunting for the right gear. Isn't that the idea?
I want that 10 speed just like the rest of you guys. I need a bigger truck than a half ton for towing and will gladly trade my 18 1500 stocker for a 22 6.6 gas 10 speed. The question is if they will do it. Their track history says it won't happen though.
Ford and dodge duke it out and gm sits and watches. Sad.
Sent from my Pixel 3 using Tapatalk
  • 1 month later...
On 2/6/2021 at 5:57 PM, TrailBoss1 said:
Due to various issues, including supply chain, there will be minimal changes for 2022 in the HD line. Maybe inclusion of the multi pro tailgate; not much else.
I've got the multi-pro on my '21 2500.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
