On 10/26/2020 at 3:45 PM, rav3 said:
I have an early 2017 & has the soft open glasses compartment too but mine fit in it fine. I didn't know they changed it in 2018. I think they list the same part nos. depending on the options (Homelink, rear glass slider, sunroof, etc.) Mines a LTZ double door, so no sunroof.
I have 2018-19 console on order (1-2 week delivery from the GM dealer) and will verify once it comes in. Part number 84456893. The details show it will only fit 2018-2019 1500s but hopefully it works in my 2017 as pgamboa suggests.
Subbed for results. If you wouldn't mind post the old and new part numbers for people who stubble onto this thread later and for us to know which one we have and what we need. Cheers man, stoked.
Side note I've always wanted the overhead console one with the mirror from the suburban to see if that'll fit.[mention=159655]pgamboa[/mention] any trial and error with that one?
Sent from my SM-G986U1 using Tapatalk
I had 4 different SUV/Truck overhead consoles and could not Frankenstein a truck version with the mirror. Reason is the center plate is different in size. I didn’t want to have to cut/modify anything but the overall console is the same size. The center plate is different.
Damn... Thanks for the explanation Phil!
I have wanted that mirror one in my truck since I bought it, kills me I can't get it but of the 50 million things we can modify on these trucks with other factory parts, center mirror not being one of them I can live with it.
O.P: can you post comparison pics once you get it in the mail? Still curious how big the difference will be
The 2015-2017 SUV OH console with the mirror fits as I put one in my 2016 Silverado.  If my records are correct, the part number was 23161771 but I'd have to pull it to be 100% correct.  Since it's a single compartment, the center panel swaps right over along with the harness.
This is exactly what i wanted. For some reason, my center plate wouldn’t transfer :(. Good to know it can be done!
Nooooo Way!!!!!!
That is awesome I will check into that part number for sure.
Thanks so much for the post man!
Maybe my googling skills aren't up to par this early in the AM, but that part # doesn't seem accurate? Or maybe the online resources I'm using don't carry it. Any chance you can double-check? Much appreciated.
So last night I was having the same problem, but a member here sent me an eBay link. I searched the part numbers database and there was a superseded part number. One you can search for is 84083238. Haven’t 100 percent confirmed fitment for this exact one, but it’s the one I will be buying here soon. Good luck
33 minutes ago, zibzer said:
Is this the part # you are confused about? 84456893?https://www.gmpartsxperts.com/oem-parts/gm-console-assembly-84456893
That's the one for the 'rados and 'erras, 2018-2020 era, yes, but the fella a few posts back mentioned using the OH console from a GM SUV...the SUV format includes the conversation mirror (hey now, that's what it's called)...which is what I'm looking for.
I saw that one too, but it's got that tailgate lift knob on it. Maybe I misunderstood @BlkSS but I'm thinking he swapped the entire console panel thingy (not just the mirror and sunglasses flip down). ?
@pgamboa, can you work your magic and retro the knob on this for a pickup?  ?
For clarity, did you swap the entire OHC or just the mirror/shades flippy thing? Also, is that a rear power slide lever/switch on the RH side of the OHC? I'ma say "YEAH" -- the reflection in said mirror suggests 3 panes o' glass.  ?
It's the center panel where the switches and knobs are
@laughey I removed my original OH console and removed the center panel along with the harness and installed those parts into the 15-17 SUV OH console as I removed those parts from it and installed the SUV OH console with the pickup center panel and harness.
And yes that is the switch for the power sliding rear glass.
@BlkSS Ah ha, so it's sorta like Legos! Groovy. Thank you for the details/specifics.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
    • I read through that and I won't lie, my eyes rolled at some of the quirks about how it can turn off the trailer braking for example but I can see how it could help control or even up the torque applied to the ground with each wheel in a boat ramp scenario. But of course what it can't do is increase the torque to the wheels if the need is there as it ends up being like driving the four wheel drive version of a two wheel drive ( high range that is ). So far the neighbor that ended up with the 3.0 duramax with the max tow package which meant the 3.73 gears and high range only, I think its been doing ok for what he has been towing but doubt he ventures off into the soft stuff with his holiday trailer. He may have towed his dads river boat locally with it ( he always used his 6.6 duramax before ), I'll have to ask him sometime if he got into a lack of power to the wheels situation as after all that engine produces a lot of torque at low speed once the turbo winds out a bit and I think it has the 10 speed and if so they have a pretty good first gear ratio at 4.70 I see which is vastly better than the 3 or four speed overdrive models of years ago.
    • I did shorter OCI"s for many years without an issue, fights sludge and wear IMO. Recently started using Amsoil, will not do the recommended/advertised miles between changes.
    • It definitely seems quite evident that emissions and fuel economy targets rule above the best case scenario of what the engines best health and life could be otherwise. Items like DI and turbo DI engines with their LSPI issues as well as cats being reduced in life if the proper levels of certain additives were allowed to be utilized and so something has to be compromised and as you point out that is the engine protection from sludge, acid and wear which isn't in the manufactures best interest regardless to worry about in this race to profits from higher sales and so if the engines wear out sooner the next sale is closer at hand.    I am hearing that its likely the two new 2027 GM half ton truck engines will call for a 0W-30 oil, now if that is an existing oil I would have to think so but we will see in the coming months. Sadly as you've pointed out to me, over the last number of years the push has been on to reduce the actual operating temperature viscosity within each designated viscosity grade so that 11.5 to 12 range for a 30 weight for example is more in that just above 10 range at 100c along with that temporary viscosity sheer dropping it even further down as per that "energy conserving" designation, not to mention how some oils are not as sheer stable as would be ideal and that mixed with a long OCI paints a picture with a little too much glitter shall we say !.    All that and the warranty gods scaring the vehicle owner into sticking with that watery wine or risk loosing their warranty coverage if they go and use an oil that is of a higher viscosity even if it meets the emissions and LSPI requirements and would never damage the engine but may very well allow for an engines longer life depending on engine use scenarios ... high ambient temps, towing etc that push oils to their limits.
