Alright guys help me out,
In my 2017 silverado Lt I have recently put a 2.5" leveling kit, with 285/70 venom power terrains on a 17x8 moto metal wheel (stock is 265/65r18), resonated tip (for looks) and a k&n drop on filter. My best average was 19.9 and is now 15.4!? I was expecting a drop but not 5 mpg!
You need to hand calculate it with the bigger tires your computer is showing you traveled less miles due to the larger tires. Also there will be a drop due to the size difference in tires and the rolling mass is increased and the contact patch is larger also.
Sent from my SM-G988U using Tapatalk
How do I calculate it? I know i have more rubber and friction and all that. But these tires are actually 3lbs lighter that BF ko2's and all the research ive done I've never heard of anyone losing that much. Also is 22 less rotations per mile alot?
If you didn't recalibrate the speedo, your readings are going to be something like 3-4% too short.
So take the old tire's rev/mile and divide by the new one. That will tell you what ratio you need to multiply your mileage by to get accurate readings.
That's still not going to improve your mpg number by very much. Raising up the front end & adding wider tires kills your aerodynamics.
It takes very little to impact the mpg's on our trucks.  They achieve optimal efficiency when stock, unladen and driven gently.  Any changes to these factors and fuel consumption will increase.    Your mpg's, with the changes you've made, sound right based on what I'd expect.  I'm sure your truck looks good and I'd switch out of the mpg screen.  On my last truck I put on larger, heavier tires and took a significant hit at the gas pump.  I simply changed my driving behavior by eliminating an unnecessary trip or two during the week.  It sometimes costs to look good!
I went from factory 18's to factory 20's and lost 2 mpg. The weight difference was about 20lbs per wheel heavier. Factory wheels and tires.........
Part of the answer is -
What was your old worst and overall averages.  You want looks or you want fuel econ?
Your new tires are approximately 1.1" taller so that is 3.5% larger which means you need to multiply your current mileage 1.035 (that is 3.5%). So your 15.4 mpg is really 15.9 mpg. As others have noted, your tires are heavier (stock were P-rated and your new tires appear to be LT rated), they are wider, taller and your truck is taller with the nose more up as opposed to having some aerodynamic rake. All that can certainly add up to nearly 4 mpg at highway speeds, that is a bunch going against the factory aerodynamics and weights. Did you also remove your air dam or do anything to it? Not much you can do but make sure the tires are inflated properly, make sure the air dam is on, maybe add a rear block to angle the nose down a hair for better aero (not lowering it) or lowering the truck a little, 2.5" is awfully larger and will add wear and tear on the front of your truck along with the heavier and larger tires. Gotta pay to play, I understood that when doing my truck so I added a 1.5" level, P-rated tires 1 inch larger but stock width and only trimmed the air dam instead of removing it, I lost between 1-1.5 mpg over stock.
Tyler
Some people say when they switch to winter blend gas the milage goes down. Are you on a winter blend now.
Sent from my SM-G975U1 using Tapatalk
Tires, it’s your tires. Add air, get a tuner (SuperChips), switch back to stock air filter and go from there.
The OP is from the other side of the state from me. We are definitely on winter blend now. I kind of ignore the fuel economy numbers from October to April and focus on the summer months, haha.
Since September 15 we all have been. I post the following about twice a year at each change when this topic comes up:
The difference between summer- and winter-blend gasoline involves the Reid Vapor Pressure (RVP) of the fuel. ... The US Environmental Protection Agency (EPA) says conventional summer-blend gasoline contains 1.7 percent more energy than winter-blend gas, which is one reason why gas mileage is slightly better in the summer.
Winter gas accounts for a MAXIMUM of 1.7% of the mpg loss.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
