Been watching this , Happy to see someone found the fix as mine has been crooked from day one, just hate to have a dealer work on it.   Good help is hard to find.
Transient,
I shared the info you provided on the camera bezel being the root cause of the distorted camera angle with the service rep. Just to prove it to myself, I compressed the bezel at the center to close the gap between the bezel and tailgate. It worked to align the camera to the center. I shared that with him also. They have a bezel on order. I’ll post a follow up when it’s installed.
Thanks again for all your help.
1 hour ago, odarevliS said:
Transient,
If you can post the part # I'll just fix mine myself
Man this drives me nuts I have a 21 and they wouldn’t do anything because all of them on the lot were like this. I took it apart and couldn’t find anything that looked out of place. Crooked steering wheel and camera haha.
A tech told my service rep in November 2020 that that’s the way their supposed to be. I didn’t believe it. You should look at Transient’s posts on this and share what resolved the issue with your service department. If all of the trucks on the dealers lot had the same issue, that doesn’t make it right. That just means they all have the same defect.
Bad news everybody.  The problem has returned, but not as bad as before.  It is the bezel.  Instead of taking it to the dealer (because I'm mad at GM for the loss of my factory navigation) I decided to take a look at it myself.  The issue can be fixed via a little elbow grease by sanding down the passenger edge of the bezel, but it looks like the square bracket holding the camera into the bezel is a bad design.  The camera has room to move, and the edges do not surround the camera the full 360 degrees.  You might be able to shim the camera angle in the bracket, but there isn't much room to work with.  That's why I went after the bezel.  It's more forgiving to modify.
Thanks Transient.
My service advisor told me they had ordered a new bezel for my truck. Another trick you might try is to reshape the bezel. I believe you can  compress the bezel in the center enough to realign the camera straight, then use a high powered hair dryer and gently heat the bezel to conform it to the compressed shape.  I compressed mine with an adjustable clamp to align it after you told me about the bezel. If a new bezel doesn’t fix it, that’s what I will do.
  • 2 years later...
My 2021 Silverado backup camera is angled too low. Can’t really see much behind me.  Also went by 2 dealerships.  They didn’t even look at it.  Just said it’s not adjustable. Hmmmm.  Surely this can be fixed somehow.  Does anyone know a fix. Thanks
We are sorry to see you are having concerns with your Silverado and would like to take the time to investigate further. Please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to your email.
  • 3 months later...
I am taking the worst time with the backup camera on my 20 silverado Ltz. It is showing way too far down. It worked fine for years and all of the sudden it just changed position. There was no accident no damage and nothing had been changed. Since then I have shimmer the camera itself which will bring it up a little but nowhere near where it should be. I replaced the camera, first it projected beautifully....but it was inverted. Once that squared itself away it went right it back to downward angle. I taped the camera outside of the housing in a vertical position and still downward. It has to be something with software or a damaged coax(unlikely). Anyone else have this happen and able to fix?
This happened to me today on my 22LTD LT TB. It is now pointing down to the bow tie.  Does anyone know if the bezel has been updated since these problems began in 2021?
Where did you get the replacement camera? Have you tried talking to your seller?
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
