Since 5.3 liters is just a couple of cubic inches short of 327 I decided to purchase some 327 emblems from Morris Designs and attach them to the bulge on the hood of my 2020 Silverado Custom.  As most Bowtie fans know, the 327 cubic inch V-8 has been historically important since the 1960's so I decided the 327 emblems would look nice on my truck.  The emblems are adhesive backed and nicely polished stainless steel so they blend well with the stock Custom emblems on the truck and bring back a little Chevrolet history.
Gonna add this under the hood of my 6.6. Thought about replacing the 4x4 stickers with something similar. But may just go with deleting the badges.
Automobile makers have historically rounded up a cubic inch or two when publicizing displacement so there's nothing wrong with a slight "fudge."?
Quoted for truth. The old 396 was actually a 402.  The new coyote 5.0 is a 307.
On 1/7/2021 at 2:32 PM, Rob Mugs said:
Hmm.. I have a 378.  Pretty sure that'd look dumb ?
You would want to go with a 383 emblem.
That's a BIG stretch
Lol. That’s a big stretch. I have a 6.2L. Which is 378 cubic inches.  That’s the emblem I would want. Nothing less or more
I remember Furd lying to their customers for years stating the fox body V8s were 5.0L when  actually they were truly 4.9L.   And yes to me that’s lying and deceiving. Go with what is under the hood. Just my 2 cents
enjoy your day gentlemen
The older 302’s were actually a 4.9L, but probably went with 5.0L for marketing. Besides, Ford already had the 300 cid 4.9L I6 in their lineup for quite some time.
Old and new.  It's still a 302.  302/61=4.95L
That said, who would put 4.95 on their hood/fenders when only a 305 is a true 5.0?
Meh.. it's a 4.95.  So, rounding up .05, it is a 5 liter
Actually it was 4.942 for some that were earlier models of mustangs.
Here is a good article.  I found it funny
https://www.google.com/amp/s/dr1ven.wordpress.com/2012/11/01/ford-mustang-not-a-true-5-0-the-hoax-is-up/amp/
GM was closest to 5L with theirs at 4.998 with the c/k trucks and cars of the 80s and 90s.
The 396 was actually a 396 until 1970, then it became a 402.  They bored it .030 over.  The 396 engine already had a good following so they didn't want to change anything.  I've heard Chevrolet did it for emission reasons, apparently engines under 400 cu in had more stringent emissions, so the they made it a tad bigger.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
