1 hour ago, Grumpy Bear said:
The beauty of dropped spindles is they have zero effect on travel and little on alignment while maintaining factory half shaft angles. If you topping out that is a dampening issue IF the spring rate has the damper at near mid stroke. Spindles nothing to do with the dampening.
Out back you have to have the room for compression to use the compression. It its skipping about again wrong dampening.
The Belltech street performance struts are designed to be set in a lowered position which maximizes the range of motion. I called Belltech and the technician confirmed this even though the struts are advertised to run in the stock length. I thought something was a little strange when I jacked up the front of my truck and the wheels only drooped an inch or two before they were off the ground. What is crazy is I had the exact setup on my '08 Sierra and no issues.
I'm running 2" beltech drop shackles with beltech street and performance shocks for a k2 truck(0-2" drop) and my rear end doesn't bounce around and isn't overly stiff. I have occasionally hit the stock bump stop on really hard dip/bumps in the road but otherwise rides much better in the rear than stock setup. I still need to get rid of the stock struts up front.
I run BellTech -2" spindles and King coil overs. Zero issues. Stock length rear Kings on a 4" drop done with dearched Deaver springs and block removal. Lovely ride. Handles nice. And yes, I hit the rear bumper on occasion. I never expected that I would be able to carry a stock hauling payload. If I had a need I'd bag it.
  • 6 months later...
All 4/6s on T1XX require cutting the frame. That's why it is now officially the gayest platform to drop with. I have no issue cutting into the frame, just not on a new truck lol
On 1/11/2021 at 10:31 AM, KriptiK said:
IHC 3/5 on 22’s
What wheels are these and what offset?
The truck looks great!
Heres my 19 on a 4/6 belltech on 24" kmc slides. Rides so much better than leveled and stock imo. Super happy with it so far.
21 elevation on maxtrac 3/5 on lowest strut setting rides ok in front. Rear you feel everything and hits the bump stop pretty regularly with nothing in the bed. Some of the rough ride is from the 24s but it wasn’t bad until it was lowered.  The worst of the kit is the driveline vibration. It took 7degrees of shims to get it somewhat decent.  Love the look and want it a bit lower but as you would expect with a cheap kit, you’ll get cheap parts equating to a bad ride.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
    • That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
