They are still working on it. They have a meeting yesterday again with both companies so hopefully will know something soon.
Again the only current issue is with 2019's with 360 Cameras which we have some new perspective and direction on now and have resumed work on those. ALL other years/models are 100% OEM perfect.
54 minutes ago, GTPprix said:
At this point there is not support for 2019’s with 360 cameras.
There will be right?  🤔
I was going to send this question in an email to @GTPprix directly, but thought it might be better here for anyone else wondering the same thing. Please forgive me if this has already been answered elsewhere or is generally a dumb question.
I’m Im ready to pull the trigger on ordering the wireless CarPlay upgrade for my 2020, but I seen a few posts back questions about OTA updates, and if it was safe to install on these radio swaps. I know the onstar services update was confirmed to be good, but are all ota updates safe?
All OTA updates work as intended.
i believe two OTA updates occurred after I installed the new module.  No issues at all. (Adding the Alexa app has been most useful).
I have a 2020 Custom TB. I understand there are certain types of units this will not be available for. How do I figure out if mine is compatible?
Using the instructions in the product description to find your radio type.
@GTPprix I still haven't received the v155 OTA for the wireless upgrade I purchased from you in January. Any suggestions? Will the dealership update it for me since it didn't come with my truck? The "cutting out" issue is getting pretty annoying.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
