When I bought my new AT4 a month ago, the dealer was pushing their Nano Protection - is anyone familiar with this process?  They said they do a light sanding and paint correction (if needed) and then apply the coating - I have a few questions specifically
is it the same as a Ceramic Coat
is it dealer specific or GM-wide?
what else is included?
Any information you guys may have is greatly appreciated.
Just about every dealer I’ve been to offers a different service. Given that, it’s impossible to know what particular product yours is offering and those questions can only be answered by them.
“Nano protection” is a relatively generic term applied to a variety of different consumer and professional coatings.
Personally, I would (and always do) pass on these heavily marked up services. I’ll stop short of calling them snake oil but some are pretty close to that. And there are plenty of DIY ceramic options that work great now.
If you want the vehicle to be flawless, keep it in Jay Leno's garage. Otherwise, just drive it and wash it when it gets dirty.
You'll never stop every rock chip, scratch, bug splatter, or other nuisance that comes from actually driving a vehicle without going crazy.
  • Like 4
When I got my wife a Pilot last year they said they put on paint protection, leather protection, undercoat, nitrogen in the tires and tinted the windows for like $1100.  I said im not buying anything I can't see, they took off everything but the tint.  I told them to deflate the nitrogen and refill with shop air if need be (they wanted $100 for nitrogen!)  I use to work on airplanes, they only need for nitrogen is if you are going from -60 to 100 degrees in minutes.
Anyway find a reputable detailer and get paint coatings if you want.
Edited by psk256
Added
There is very little details about what the dealer coatings actually are. Zaktek which is a big one pushed by a lot of Chevrolet dealers, seems to be something between a true ceramic coating and one of the cheaper spray on ceramic coatings. But no one will actually tell you what it is and there's almost no information on it.
I would just skip it and get a true ceramic coating put on aftermarket from a detailer. If done right, a true ceramic coating should last you 1-2 years.
Skip it and do it yourself
I am waiting to receive my 2021 Sierra AT4 CarbonPro. I bought Avalon King ceramic coating and will be doing it myself when the truck arrives. Fairly easy with little prep on a new vehicle, will post after I get it done.
I just got done detailing my Sierra. 2 coats of Adam’s Polishes wax, and jet seal.
Looks amazing. Same leveling of detailing that I did on my Porsche.
For the seats use a horsehair brush and either Adam’s leather conditioner or Leno’s garage leather conditioner.
I would hard pass on anything from the dealer.
ditto.....pass on it
nd pretty sure normal air is mostly nitrogen anyway, lol......like 75 or 80%
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
