I've been debating on selling my Pulsar, but only because I want the tuner option.  I figure if I sell it for 300, itd be valuable enough to anybody that needs those options.  It does do what it says it will do, and they do have an afm/dfm dongle I believe as an alternative.
What tuner option are you thinking of going with?. I didn't think they unlocked a tuner for 2021 6.2 yet? Will the tuner your thinking of shut off DFM to? Thank you for any info.
Edited by Liquid Plumber AT4
  • 5 months later...
Oddly I have that same issue mentioned about the driver side blind spot light staying on.
I also have an engine code that have not scanned yet but keeps returning as well as my remote start does not work!
I like the features of the module for the auto stop disable as well as the throttle sensitivity but I’m not keeping it if I’m going to have these and who knows what other issues later on.
I have a 2019 silverado high country with the 6.2 . I am having problems with the pulsar lt. It causes my truck to go haywire. The first one cause the esc and check engine light to come on. So I got a new one sent cause I have a warranty.  The second one cause my check engine light,  tc, loss of engine power 4wd and some more . Is anyone had this and what is the fix for i?
I have a 2019 AT4 6.2 10 speed with Pulsar LT and have not had any really issues. I did have a couple weird warning lights at first but have not had any issues for almost a year now. I do plan to buy the OBDII to USB cable so I can keep the Pulsar updated at some point here just wish it was included with the price these cost.
Did you check that none of the pins were bent in the harness?
Hi, have you sold t your Pulsar LT yet? I am interested if you still have it and not damaged….
thanks….
thanks….
Waiting for an opportunity to be without my truck for 3 days.  Need to send my ECU in.
I have read everyone's comments about the Pulsar LT, I have a 2020 Denali 6.2L and had it installed in my vehicle for a year but I recently removed it due to the following issues. I went to lunch one day from work, less than 3 miles and on the way back the AC quit working, the DIC indicated Service ESC, Service 4WD, Service rack in pinion steering. Based on the info I read on line, I let the truck sit for an hour and went back and started the truck and the AC was back on line but the trouble codes remain. I used the Pulsar LT feature to clear the codes and the truck went back to normal. Simple glitch I guess. Fast forward two months later, driving back from Kentucky and North Carolina, over 6 hundred miles, coming into Alabama cruising 82mph and once again, AC went out, Service ESC, Service Transmission, etc., same issues. I had to pull into the rest stop 6 miles later and pulled the negative battery terminal and let it sit for 20 minutes while I stretched my legs and ate a snack, some what embarrassed with having the F150s, Tundras, and Dodges go by looking at my GMs flagship Denali with the hood up. After reinstalling the negative battery terminal, the vehicle was back to normal. For the comment about the auto side steps, anytime you pull the battery, the side steps need to home themselves and its seems to look like it goes haywire, but it is normal as well as rolling the drivers and passengers windows up and down. You learn this through ownership. Once I returned home I gave it another two weeks and nothing happened. I decided to remove the Pulsar LT and send it in to Holley before the warranty runs out and have them check it out. I called their tech support line and explained to them what happened and I was told that I was the third person that this tech support guy heard about with the same issues as other owners of the Pulsar LT. They gave me an RMA number, warranty is only good for 1 year, three weeks later, I received my Pulsar back and they stated, through their analyzing they could not find nothing wrong and they programmed the box with the latest update and that was it. However, I haven't installed it back to into the vehicle. It has been over three months, no faults, no check engine lights, I drove over 3 hundred miles and back in the fourth month after this, no faults no check engine lights.  So your guess is good as mine. As far as programming, I did have the USB OBDII harness to update it and it is periodically checked, if programming comes into mind,  and no you can not do anything with the programming because it is all automatic with the software, you plug it in and the software or Update Agent does the rest.
Edited by AsianCajun
I have had the exact same issue with my Pulsar LT and Sierra 1500 AT4 6.2L.  It will happen anywhere from 1-2 times a month.  When I contacted Range, a couple months ago, they said they had not heard of that issue.  I bought mine over a year ago so I'm out of luck with the warranty.  For the longest time, I didn't connect all the service warnings with the Pulsar LT until I started reading about others having the same issues.  What I usually do is just disconnect the negative terminal of the battery, wait a minute, and then reconnect it.  That clears up the issues.  Do you think that an update to the Pulsar LT will correct the issues?  I really like my Pulsar LT and all the flexibility it offers, and I don't want to get rid of it, but I'm tired of having to disconnect the battery every couple of weeks.
I had this issue a couple of times with my 5.3 since I installed the Pulsar.  Last time was about 6 weeks ago when driving home from the vet with my puppy on a 98 degree day.  Finally got it home and remembered the fuse block TSB.  All 4 bolts were over a turn out from the proper torque setting.  Torqued them down properly, and haven't had it happen again.  While sitting in a parking lot, I did try to just disconnect the Pulsar, and in the process popped off one of the red dial retainers.  Anyone know if those can be purchased separately?  I'm going to have to remove it before my inspection in December, so I may as well replace it when I do it.
Did anyone notice the 10 speed transmission acting weird (hard shifts, seems like it doesn’t know what gear to be in, clunks) when they installed the pulsar LT on their 2020 5.3?
On 8/31/2022 at 4:19 PM, Johnny Johnston said:
Over 20k miles on my Pulsar, took it off a few times for oil changes etc.
Never any issues yet of any type, works as it should for me and I am very happy with it.
Cheers
Not as many miles but a couple months on a ‘19 5.3 8spd.
zero issues. Love it!
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
