Hello. Previously I had installed an inverter in my '08 Yukon. Great for computers, etc. My goal this year is to install an inverter in my '20, placing it in the back seat of the crewcab. Lots of options out there for inverters depending on use.
Cheers
The one in my Sierra 1500 ran my angle grinder no problem.  Haven't tried it for anything else.
How much power does your grinder draw?
It's just a little 4" grinder, think 4.5 amps.
4 hours ago, redwngr said:
Is that in the Ford Hybrid truck?
That's clearly the 7.2kW and, yes, truck's got to be a hybrid.
How do we know from that picture that it's 7.2kW?
Does the 'full electric' 150 have something similar?
I didn't / don't even know that it's Ford rather than some aftermarket installation.
(Yes, I recall seeing the Ford commercials -- which is where the guess came from)
You can see the 20A plug.. don't know about the "Lightning" but it handles 9kW, more than the hybrid's 7.2kW.
Look at the metal around the electric panel, it's clearly not aftermarket. And I would recognize it because I've been lookigng at Ford trucks lately. I want something to power the house in Mexico when I am down there. Nice thing about that is that if I'm not using a lot of energy, it uses the big battery from the hybrid part of the truck. If I use a lot more electricity, and the battery in the hybrid is depleted, it will start the truck so that the battery can be recharged.
It's been estimated that it takes 1 gallon of gas to give a Tesla 30 miles.
Certainly seems to be a better system than the 'hybrid' pickup that GM for a while offered 15 years ago.
Edited by redwngr
So a Tesla gets 30mpg, but costs much more to purchase than a 30mpg ICE?  Is starting to make a little bit of sense to put a large inverter into a Chevy Trax and use it to power a house.
On 2/20/2021 at 8:20 PM, Dunn said:
pretty useless for me tbh.....am contractor and had one in my 2500, for tailgating and such not construction purposes
I was sold on it when I saw the chop saw in the sales brochure. Got my 2021 Sierra and plugged in a little 10” …. Spun for a good half a second and shut down. Tried a duel pack drill charger … nope. So now it charges my cell phone sadly !!
This is a game changer Ford brought out. We recently went camping with my buddies Power Boost and literally plugged in a space heater all night .  Watched the Super bowl on a 35in spare TV we brought out, cooked , made coffee etc.  I know glamping at its finest!  I wish Gm would give us this option in the regular Silverado and not just the EV version.
That is one of the reasons why I have gone back to Ford. The idea of not dragging along a generator is very appealing and there are times I need to power up the house in Tijuana when electricity becomes unreliable and the lights flicker, potentially damaging computers and electronics. I have friends who are plugging their trailers with it, it's incredible. I am not a tree-hugger but I do want a hybrid due to the long border waits, stop for 30 seconds, move a car length, stop for 30 seconds.. about a mile away from the border which takes 3 or 4 hours. Hybrid fits the bill nicely.
I just traded in my 2021 F150 Lariat on a 2022 Sierra Limited Elevation. My Lariat had the bed outlet and it was useless too. If your wondering, my F150 was at the dealer for 6 weeks with a charging system issue. Ford said they needed more time to fix it, I said no and traded it in for my GMC. Too bad for Ford, it was my 3rd F150.
    • I imagine the cold winters up here with repeated short runs in town every day for those that live and work in town and given what I have come to learn on this forum with DI engines having fuel dilution issues, and if they don't change the oil until it says to but keep driving it for a while, I bet all that is just lovely on those finicky lifters.
    • I just did some reading and Stabilitrak is more than a what I had originally thought. It is more of a vehicle control system to help the driver in precarious situations. I thought it was only the AWD system. Now I know. So I changed the title for this thread to AWD conversion to Z71
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
