Just curious now that the brand new models come factory w wireless CarPlay ... have we found a way to upgrade older year models? Like they did w navigation and CarPlay and android auto in trucks without by changing stereo modules?
ive got a top level slt version w all the stereo options... I know wireless CarPlay works off a mix of WiFi and Bluetooth...and my system has both modules....
any help on this matter would be greatly appreciated
Edited by Sickness1972
I ordered the carplay2air should be here this week. Will update you once I have it up and running
I’m interested to hear how those work but I wonder if we can just replace a module in the system from a brand new truck, into mine and make it work...
I know folks have done this in other trucks .. with navigation ... or with wired CarPlay so I am sure it has to be able to be done
Not possible from a factory retrofit standpoint. All new hardware and communication bus.
@pgamboa who do you suggest for a complete upgrade... I have seen you post about a aftermarket company that has all the integrations ...
I also read somewhere that Pioneer is soon to be releasing a specific plug and play receiver for these GM’s built off there NEX entertainment lineup package... but I have no idea if they went thru w it, if it’s still happening and if it is, when it will be released
Wireless just came out for the T1 new body 2021, which have all new and different radios, modules and radio operating systems compared to K2 trucks 2014-2018.
There is a device in the aftermarket available:  CPLAY2air wireless adapter for factory CarPlay – CPLAY2air.com
I have the CPLAY2air in my truck and so far works very well. I tried it in my wife's Honda and it  worked well there also. Its about the size of a business card and i leave it in the center console and my phone stays in my pocket. I am going to order another one for my wife.
Does this work with Android Auto or Carplay only?
I bought that (CPLAY2air) and I was unimpressed.
Too long of a boot time and my audio was degraded as well as response time.
Otherwise, it  well ... just worked.
I wasn't happy, I stayed with plugging the iPhone in.
Has there been an update recently?
Edited by MikeBMW
Spelling
Was the audio worse then just using Bluetooth?
I just received the carplay2air unit Friday. After using it all weekend I have not noticed any music issues- it works great. Simple set up
i modified the armrest for wireless charging with an Apple MagSafe charger set the phone there and it automatically connects to the truck and brings up CarPlay. Have not noticed any lag etc.
Edited by Sean006
Yes, the audio seemed degraded.
Great information and feed back, thanks!
I'll give the device another try.
Much appreciated! :)
Edited by MikeBMW
Had a chance to check mine, tested boot time 25 seconds from engine start to carplay on screen. Audio quality I am not a good judge, but swapping between cable and device I cannot tell any difference. No lag that I notice. It is a crazy price for a usb dongle, but for  the short hops that I usually drive it is very convenient. Checked my firmware version     ver:2020.11.10.2137
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
