Active Fuel Management (AFM) and Dynamic Fuel Management (DFM) will not be available on certain 2021 model year Silverado 1500/Sierra 1500 pickups
On 8/1/2021 at 2:29 PM, Dave Felten said:
I recently purchased a 2021 RST with a 6.2 L 10spd.  How do I verify if it has AFM/DFM or not?  I don't see any display of deactivated cylinders on the drivers displays.  I've read that certain engines were not equipped with AFM/DDM due to chip shortages, wondering if mine is missing that component or not.  Thanks.
This will be specifically identified in the window sticker.  Mine says "credit-not equipped with dynamic fuel. Management -$50"
Edited by ratman6161
On 7/26/2021 at 6:32 AM, honkongphooey said:
I have been reading threads and articles on AFM - problems, performance, benefits etc and am leaning toward disabling AFM (NOT DELETE) and know about driving in L5 (mines a 2021 custom with 6 speed) to not engage cylinder deactivation.  I tried an experiment where I drove 10 miles on highway at 65 in L5 and cruise on and got 20.2mpg at 2000rpm. I then drove same stretch in Drive at 65 with cruise control on at 1500rpm. got same mpg of 20.2.  would have though there would be a difference. any ideas why not?
At that speed our trucks become to much of a brick in the wind for cylinder deactivation to activate it seems. Do the same at 45-50 and you should see a huge difference. I can see 26-28 at these speeds while only seeing 19-20 at 65.
Traded 2018 LT Silverado  2 weeks ago for 2021 trailboss custom  without AFM!
oh what a glorious day!!!!! Fuel mileage is worse, compared to the 18 best I could figure, it is about 1 1/5 miles to the gallon😜 But who freaking cares it’s a V8 24/7!  Plus this truck just looks and feels better than the 2018!
They all have the same lifters and camshaft so technically everyone has DFM. It should tell you when you go drop cylinders and the exhaust note will change.
Don’t believe the new trucks have any indicator on the dash at all as you describe.
If you want to know if you have it scan the QR code in the drivers door and look to see if it has build code YK9. If it does, you do not have afm/dfm. If it does not, you do
Ah haven't drove a new truck so couldn't tell you. I just remember in my dad's K2XX Suburban it was like that
My 2021 Silverado HC has the 6.2L / 10spd combo and no AFM and no stop/start.  Coming from a 2014 Sierra Denali with 5.3L 6spd, with AFM.  This new one is incredible. Instant power and the drivetrain feels so much more solid and stable.
When looking at the new ones, the 6.2 window sticker shows better fuel economy than the 5.3... but I am definitely getting a little worse than the old truck did.  Not much worse, but a little.  I'm pretty sure it's because my new shoes are heavier than before... I can't seem to stay off that gas pedal.  😜
I just noticed 2 local GM dealers got an influx of trucks recently (over 20 between them, 21 and 22 models) and they all have DFM.  What they don't have is Stop/Start.
So, I've had my 21 SLT X31 for 3 weeks.  Just looked at my build sheet and I do not have DFM.  I also do not have the HD radio.  Both show a 50.00 credit. So I'm assuming, with no DFM, I will not to have to worry about the lifters collapsing?  Build date 10/21.  I do have stop/start.
Edited by haider320
I have had mine a week now. No DFM either. Although it shows I have HD Radio on the screen, I have yet to get it to work. My build date is 7/21 according to the sticker. Guess the dealership had this one laying around a while.
 mine built in June is the chip shortage truck too.  I also have the HD radio , but I found it in settings where I had to turn it on.
The button on my screen turns mine on and off. Even looking through browse, it shows up no HD stations even though I know there are some in my area.
Edited by Byrds8
Mine did the same until I turned it on in settings.  The radio screen icon now goes to active when it is in HD.  It didn't do that before when I thought it should.  That's why I started looking in the settings menu.  Maybe yours is different.
Yeah I had gone out there and looked. If I turn it on in the settings the sound goes away just like touching the on screen button. Not sure what is going on with it but it is on my list of things when I take it in on Saturday.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
