Hi All - former owner of the other brand, I have an opportunity to buy a 2020 Denali w/ 6.2L and 60k miles.  I am trying to learn as much as I can about the GM platform as this is my first GM.  Wonderful forum here.
I'm struggling to find anything that says "I have 100k+ miles on my MagneRide suspension".  How reliable is Magneride?  Everything I'm reading relates to Magneride failures and people swapping Magneride for more traditional suspensions.  It is just assumed that MagneRide needs to be replaced every 50-60k?
Looking for any comfort that MagneRide is worth it and is not an absolute pain in the rear.  I keep trucks for a long time and would hope to drive this one for 200k+ miles but if its going to cost $3-4k every 50k miles, I might go another direction.  Fwiw my current daily driver I bought 20 years ago, summer of 2001, to give you a sense of my ownership style.
Thank you in advance for any help!
I wouldn't have a truck with that system. $$$$
To me, the Magneride in the Tahoe/Suburban/Yukon ride no different than one without it.  You don't get to really see how Magneride makes a difference until you step into a Corvette or Camaro with it.  On those you WILL notice a ride difference between touring, sport and track.  There's no modes on the 2020 and older SUVs to alter the ride.
I would get a Yukon without it as its $$$$ to maintain it.  The shocks and struts in the SUVs are lucky to get past 50k.  A Camaro or Corvette?  Totally worth it.
Edited by newdude
3 hours ago, Grumpy Bear said:
:lurk:
I've got enough forum experience elsewhere to know what this means.... Though this implies that there is a group in the pro-MagneRide camp..?
Though really the root of my question relates to whether there examples of MagneRide suspension lasting >50-60k.  I realize its expensive to replace and honestly if/when I replace I'd switch to Fox or something simple.
Not here to debate ride merits.  Not here to debate whether its expensive or not.  Just here to learn if there is a chance I'll hit 100k before needing anything or if by purchasing it with 60k already, I'm facing an immediate suspension bill.
Thanks all!
I intentionally looked fora Yukon XL without mag-ride.  I didn’t even ask anyone.  Didn’t even test drive one. I went to standard suspension.  Good luck
I'm not that dark. It means that I don't know but am as interested in the answer as you are. At least that's what it means today. 😉  Welcome to the group!
Thanks all!
We've replaced them in the 30k mi range, 40, 50, etc.  Leaking badly and or the shock fails and stiffens the ride straight up.
2019+ trucks do not have Magneride.
Well there goes this thread.
op why are you saying that it has it?
Our 2016 Suburban has a harsh ride if you ask me.  We already had to replace our left front shock due to leaking at 75k miles.  At least our extended warranty covered it.  Which with that repair and the AC condensor, those paid for the extended warranty.
Edited by Black02Silverado
Not Magnetic Ride Control
Adaptive Ride Control (GM RPO code Z45) is not just another name for GM’s incredible Magnetic Ride Control, since ARC does not use magnetic dampers/magneto-rheological fluid. Instead, it uses different (and perhaps less sophisticated) active dampers.
Magneride is rpo Z95
Edited by elcamino
In full disclosure, I'm looking at a 2020 Yukon XL.  I posted in this forum as it appears to be much more active than the Yukon / Suburban forum and I was hoping to get a handful of responses from owners with 2013-2016ish trucks who might give me a sprinkle of hope that this suspension isn't just expensive trash.
I hated the mag ride. It was awesome in the Camaro and the cadi cts I drove that had it, but the denali I hated it.
it gives so much feedback. You can feel basically running over a quarter in the road. I want my luxo barge to be luxurious, floaty, and silent. I don’t want to know whats going on in the outside world. I want cracks in the road, potholes, and small children to give me zero feedback when I run over them.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
