I'm about to change the transmission fluid in 2016 1500 Z71 5.3. What is the best Transmission fluid to use. I know the 6L80 has issues, currently looking into resolving it, but until then I'm going to just change the fluid.
Avoid GM/AC Delco at all cost.  If not AMSOIL, then go Mobil 1 as 2nd best.  Nothing but problems with GM branded Dexron in new 6 and 8 speeds.  Contrary to popular belief Dexon is not synthetic and the transmissions perform better with 100% Synthetic ATF.
Changing the fluid is the most important. Yes, there are better fluids. I have used Castrol Transmax many times in different makes with no problems.
Yes, keeping it fresh is a good thing and as often as that is done, the cost isn't that much.  So if you can change out every 40k life will be good.
Best?
For a 6L80/90E?
A Dexron VI that you change
Often.
IF the question you actually mean to ask was which Dexron VI ATF checks the highest number of technical boxes.....
Is that the real quesition?
1 hour ago, Vom Breezy said:
I was just asking which brand to use. I know to use a full synthetic.
If you want a quality full synthetic then you would have to go with Red Line or AMSOIL.   If you are interested in AMSOIL and can't get it locally, let me know and I can send a quote on cost delivered to your door.
Oh boy :crackup:!!
For the six speeds my personal preference is Red Line D6.
For the 8 and 10 speeds the AMSOIL ATL or Mobil 1 Mobil 1 Synthetic LV ATF HP are the only two choices.
If you prefer AMSOIL, their ATF for the 6 speed.
Take note AMSOIL has both a ATF and an ATL. Don't confuse the two.
AMSOIL Questions?
Ask Nick.
(Black02Silverado)
He's the resident AMSOIL guru.
Dexron VI is full synthetic.
What issues?
2 hours ago, silveradosid said:
what about vavoline full synthetic dexron VI
Once again we get into the Mobil/Castrol Law Suit war on the definition of SYNTHETIC.
Valvoline is a Group III.
AMSOIL and Red Line are Group IV and/or Group IV/V. (PAO or PAO/Ester)
There is nothing wrong with a Group III mineral oil based marketing synthetic.
Valvoline is my go as a third choice as would be any other Group III.
Note the distance between a Group III and a PAO. IF you could be assured it was indeed a Group III+ then the difference is almost non existent.
The higher you get on this list the more natural heat and oxidation resistance you have. Esters are not on this graphic but would sit above it. This does not mean a PAO is a mineral oil based material.
PAO is a synthesized hydrocarbon that does not occur in nature made from hydrocarbons that are.
Esters are made from fatty acids and alcohols.
Where the PAO/Ester fluids will take a a short hard overheat without damaging the fluid itself the same can-NOT be said for other base oils. So if you choose Valvoline or Castrol or XYZ and overheat it....Change it. Yes even if you just put it in yesterday.
That said. Remember that an overheat damages more than the fluid. Seals and clutch bonding materials are damaged as well with repeated trips to the hot zone until they fail no matter what fluid you use. Yes that can be even once IF the temperature is high enough, long enough.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
