Hello
I am trying to figure out which spark plug wires fit my engine, but I couldn’t figure it out.
Mine is 2018 Tahoe Premier 5.3L
I was looking for Accel (part# 9059C) & MSD (part# MSD33829), but for both, some websites claims that it will not fit!
Can someone confirms which may fit so I can buy.
I am welling to use ACDelco sparks plugs
Thanks
https://www.holley.com/products/ignition/spark_plug_wires/accel_ceramic_boot_spark_plug_wires/parts/9059C
https://www.amazon.com/MSD-33829-Spark-Plug-Wire/dp/B01FV3GR3O
 The oe wires are best, same goes for plugs. CSP swapped in msd wires on a C7 build and they lost 40 something horsepower compared to acdelco. The msd's had no damage and were functioning properly. Apparently its not all about resistance.
Stay away from Granatelli. Any company that sells a ported maf sensor should be avoided like covid-19!
Edited by M1ck3y
This is the MSD size that fit my old 2014 5.3L engine:
# 33829
I am running Taylor wires now on my Silverado which I like a lot. Better than MSD. part number is:
# 79613
I personally don't like the factory wires or plugs. I find both fail way too soon. Replaced every set on over 5 GM trucks before the warrantee ran out usually. Always been happy with the results, and always found the factory sets in bad shape in as little as 40k miles. Would never buy them. I have heard that too low a resistance can lead to misfires, but have not had that issue with the Taylors.
 need resistance in the wires and in the spark plugs, otherwise the coil doesnt charge up fully, you'll get weaker spark. the resistor is apart of the engineering, by holding back the energy until it blows it's load so to speak.. and its needed for noise suppresion so not to interfere with the ecu , radio, bcm, etc..
a points distributer likes low resistance, because its all mechanical and takes time to transfer spark thru the ignition, HEI is different
Edited by pokismoki
Spark happens AFTER the coil is charged. Coil near plug systems so have more than enough time to charge...fully. Not one coil per eight but eight coils per eight. Coils fail to charge fully when the time between sparks is less than the rise time of the coil. If what was being said were true then coil on plug systems would not work at all. Right?
This is basic Ohms' Law once the system 'asks' for the spark.
Spiral wound wires provide more than enough suppression IF the wrap per inch is high enough.
why does Honda use a resister plug on their single cylinder thumper dirtbike motors??
if the resister suppresses current, does this mean it improves the voltage spark?
this was informative for me..
Edited by pokismoki
40 Hp wow, is it possible they are giving off so much noise it's effecting the ignition timing. those wires might be designed for Magneto ignition and not HEI COP style
They were the wires MSD specd for the LT1/l86 etc. It was a high horsepower build. I imagine the difference on a stock engine would be minimal.
When I have time I'll try and find the video on YouTube again.
*Edit*
The focus of the video wasn't about how the msd's lost power so I can't search for it and pull it up. Way too many videos to go through. If someone has an interest in hunting it down, the video was done by complete street performance.
Edited by M1ck3y
Current is energy. Voltage is potential. You light a fire with energy. A few millijoules. About 17 millijoules will get it done if everything is perfect. It rarely is. You jump the gap with voltage. Want more voltage increase the gap. Takes about a thousand volts per thousandths of an inch of gap in free air.  What has more resistance than air? Just because a coil can put out 50K volts doesn't mean it will. It will put up what it needs to jump the gap. Not a volt more or less.
Older English bikes used carbon/cotton wires and non resistor plugs and some dismally weak coils. Kettering ignitions are not bothered by noise. Honda's electronic systems are. They could use a suppression wire or plug but both is never required. They became popular in cars when AM radio got to be a big thing.
Honda cars. The 4's anyway are coil on plug. There is no wire thus no resistance that is not provided by the plug. By present argument these motors shouldn't run should they? 😉
Read the Magnacore link M1ck3y6 provided.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
