UPDATE
I forgot the owners manual states change the oil and filter at 3750 miles if you meet certain conditions. Our driving meets 3 of the conditions for 3750 OCI's. This is why I was doing 3 K mile OCI's like I have always done.
Conditions
1 Repeatedly driving short distances of less than 5 miles (8 km) in normal temperature or less than 10 miles (16 km) in freezing temperature. Our trip to town is 6 to 8 miles depending on our destination. Round trip is over the low mileage.
2 Driving on rough, dusty, muddy, unpaved, graveled or salt spread roads. Dirt roads are the norm.
3 Driving on uphill, downhill, or mountain road. This type of roads are everywhere we go.
Now I'm second guessing going 5 K OCI's. I figured the better oil filter( 10 K mile) and Amsoil oil (7500 mile) it wouldn't be a problem running this combo for another 1250 miles.
Yes, I know I could do a UOA and I might.
Opinions please.
55 minutes ago, diyer2 said:
UPDATE
Conditions
Opinions please.
I think it will be just fine.  I understand the short distance and other conditions.  I'm now in the shorter driving distance since we moved.  Before we had to drive 20 miles to get anywhere, now everything is withing 2 miles from the house.  No hills or dirt roads though.
You can do a UOA to see how it goes, but to me not needed.
DIYER2
Does your Hyundai burn clean, operate at optimum efficiency? The recommendations in manuals are for lowest common denominator. Does it have any wear issues that you can't explain etc.....
Grumpy and Nick are right in 3750 miles most API certified formulated to a minimum oils will do fine.
I live in similar environs at 9000' in CO on mountain remote roads but aside from change the air filter more often and making sure its well seated to seal out that dust and fine volcanic rock it does great.
Another consideration is fuel usage and altitude induced drop in naturally aspirated power. If you are above 4000-5000'  most of the time you are producing less HP and using less fuel generally.  Thats easier on the engine just by less fuel used.
customboss,
House is at 9200. Elevation varies from 6000 - 9500 during our travels.
I just reread this thread. A lot of the info you and Grumpy post is over my head and I bet a lot of others heads.
I do believe Grumpy stated the Castrol Edge and Amsoil OE are a lot alike. So I'm still confused if the Amsoil OE is an upgrade form Castrol Edge. I think it is but I'm no chemical engineer.
Ordered the Amsoil OE oil and Purolator One filters. $8 dollars more per oil change than Edge oil and Wix filter. Will do 4 K mile OCI's.
To me this is a good compromise as opposed to more expensive oil and I believe it's and upgrade that is cost effective.
Thanks all.
  • Like 3
Sorry fellas.
Considering all the replies, opinions and lab talk I have 1 question.
Does the Amsoil OE oil provide 47% more wear protection?
15 minutes ago, diyer2 said:
Sorry fellas.
Than what?
How about we define the point of reference first.
To what are we comparing it?
Give me a chemistry.
2 hours ago, diyer2 said:
Sorry fellas.
Amsoil likes to use 4 ball wear testing comparisons and yes it might if that’s the reference.
BP Castrol are masters of R&D in Pangbourne ,England. Then hire out lowest bidder blending all over the world to keep costs low to compete with getting shelf space at Walmart.
Great formulations but first to deceive US market with defining GRP III highly refined petroleum as “synthetic”.
Show us the 47% claim so we can define what that means to your needs.
So 47% more wear protection is B.S.
Again I think it's better oil than the major brands available off the shelf.
I remember reading the base stock used in Amsoil is refined more so it has less junk in it. True?
  • Confused 1
diyer2  not necessarily.
I asked you where that 47% value came from?
Show me so I can answer your question based on science not marketing. Amsoil does not make claims lightly, they usually back it up with testing of some sort.
On 11/19/2021 at 9:55 AM, customboss said:
DIYER2
You never answered this query either.  The tune of your Hyundai matters more than the oil you use.  However if those two products were my choice I would order the Amsoil from Black02Silverado
7 minutes ago, diyer2 said:
OK thats  Peugeot TU3M Wear Test (CEC L-38-A-94)  test limit for Dexos1 GEN2 0w20 is 15 um of cam scuffing wear. Being at 8 um is great, disclosing their test result is even better!  If you want to know the direct correlation find the Castrol Edge 0w20 values.  I am betting your research will only say it passed the 15 um limit of scuff wear.   OW-20 was tested because DEXOS requires it for GEN2.
Hyundai does not require DEXOS testing but its a good guide to exceeding cam scuffing wear testing.
Anyone have access to Castrol Edge 0w20 Peugeot TU3M Wear Test (CEC L-38-A-94) test results?  We know their DEXOS marked bottle would met 15 um or less.
Of the 4 Hyundai’s I’ve owned two still are in the family. The 05 Elantra GT the wife’s first Hyundai. The Grandson drives it now. It gets the normal maintenance schedule. The 11 Genesis has had the severe maintenance schedule as the dealer recommended. I resisted but we paid extra for extended warranty. I didn’t want excuses. No extras, no additives. And no tune ups. Both server their owners well.
  • Thanks 1
Ford lost a future head of engineering to Hyundai/KIA and he turned that place around for sure.  Ask anyone who bought the first versions to market in US about their automatic transmissions...  The engines are flawless unless an early rod bearing issue reveals in the 4's.  They pioneered GDI when Ford was building Ecoboosts that carboned up the valves in literally 10,000 miles.
That Genesis 3.8L ( I think)  is amazingly well built.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
