5 hours ago, diyer2 said:
I forgot to post this feature that is on our Santa Fe. You can set the OCI to whatever you like, I have it set at 3 K. Currently have about 3300 miles on the first Amsoil OE. Still shows full on a cold overnight level check. Oil isn't as dirty as the Edge would be. Thinking of going to 4K.
Our daughter just got a Kia Sportage and you can do the same thing.  Pretty cool.  You can also set the turn signal to blink either, 3 or 5 or 7 times when you just bump it.  I wish my truck did that.  I don't think 3 flashes is enough when passing and changing lanes.  7 would be preferred.
Ram trucks are doing this like for ever
If it detects a trailer it will extend the blinks automatically. But no way to manually change the count on the GM. Or my Ram for that matter.
  • 2 months later...
Back on topic. We took a 2/1/2 day road trip covering 600+ miles with 2 nights in a motel. Driving conditions included lots of curvy mountain roads, flat straight roads with lots of elevation changes.
The purpose of this update is the car used no oil which I attribute to switching to Amsoil OE. It would use a little oil when using Castrol Edge. 😀
Edited by diyer2
  • Thanks 2
  • 3 months later...
Amsoil oe isn’t very expensive. 7 buck some change per quart.
I used Castrol for a couple years and 5000 mile intervals. Did an analysis with edge and the numbers were great. Could have gone longer. I’ve got oe in there this winter. Will do another analysis.
that said, if I were truly worried about the cold I would try 0w30 rather than my normal 5w30. The first number is your cold crank number, the second is your normal running number.
CASTROL  is a British Oil Company
AMSOIL Is an American Oil Company (Superior, Wis.) since 1972!
Buy American IMHO, I have for over 30 yrs.........................
Edited by elcamino
  • Like 3
  • Thanks 1
Oil filter change 2019 Santa Fe.
4037 miles. Amsoil OE 5W20 and Purolator One filter used.
It was down about 10 -12 ounces I would guess. I have been checking it once a week so I knew it.
I don't think the oil usage is bad considering our driving conditions. Meaning our constant elevation changes puts more strain on a motor than flat landers. Would I like to see no usage? Of course.
  • Like 3
You can but it will cost.  White Auto and Media can do it.  I would like to extend the flash like it does with the trailer hooked up.  But the cost is not worth it to me at least.
I was watching drag racing recently and the sponsorer was Amalie Oil Co. Never heard of it.
Amalie Oil Co.
Edited by diyer2
Amalie Oil Co.
Been around a long time. Quite company like Lubrication Engineers.
I have always checked my oil after sitting over night. My Santa Fe manual says to do this with a fully warmed up engine, shut it off, let it sit for 5 mins. then check the oil.
I tried the manual way for a test. Oil level after sitting 5 mins. maybe a tad lower than a cold overnight check.
The difference is so small I will continue to do overnight cold checks.
I'm envious. Terrian is 4 ounces different between 5 minutes and 20 and a pint by morning. It's that stupid cast in oil filter without a anti-drain-back feature. :mad:
20 minutes is a long time to sit at a gas pump :crackup:
Good for you! :thumbs:
I understand someone like Grumpy being ultra diligent with oil checking. Several times with different vehicles even lately with the CRV when I first got it. I’m on my first trip checking the oil at the first gas stop. OMG! It’s down half a qt. So now I’m thinking about it throughout the whole trip with the dipstick dance. The whole trip was 3K miles. Once home in its spot the next morning dead on full. The low to full mark is one qt for a reason. I had forgotten. I even had an oil user from new. After the first 2K miles I switched to Amsoil. 5K miles later on the road I check the oil. 3 quarts low. I add the 3. 100 miles later I’m home. The next day 1/2 qt over full. I never top off on the road unless it’s under the one qt add mark. Then only 1/2 of qt. It has only been that one truck.
I check my oil regularly. Simple task.
I gain the knowledge of how much oil is used, if any in X amount of miles. On a trip mileage tells me oil usage.
But I still check it very morning because you never know.
Easy insurance.
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 642 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
