Anyone using the oil sampling service from Blackstone Labs?  Thinking of ordering a kit and sending an oil sample for examination.  I would rather get a sample through my dipstick tube, but I have yet to find anything that will work for that.  Any ideas?  If so, send me a link.
  • Confused 1
I've used them in the past, they do good work and I trust their results.
Not sure what you need to use to get it through the dipstick tube. It will need to be a really small hose to make it's way all the way down to the oil.
Yep, I've used Blackstone some. Also have used whatever service that WIX kits use. Only thing I know to try is to go to Lowes or Home Depot or local hardware store and see what kind of tubing they have to choose from. You need something small enough to go through the tube but have some stiffness to push through the tube
Edited by txab
sp
AMSOIL sells a tool for that BUT don't know if bottles other than theirs fit and it comes with 10 ft of hose, no bottle w/tool, that comes with the kits they sell.   And no, they do not do the testing, it done by Polaris labs, an independent lab..
Edited by elcamino
I have used Blackstone for analysis many times before when I had an Ecodiesel. I like the way the kind of dumb down the report for us non technical users.
I used 1/4" water line PCV tube from home depot to stick down my dip stick tube. I assume it will work with this truck too. It takes a few rounds of dipping,  putting your finger over the end and pulling it out, letting it run into their bottle to get it full. Not bad.
Unless you have a specific reason to get it sampled I'm not sure I'd waste money on these engines. The few issues they have wont show up on an OA.
Amsoil uses Polaris labs for oil testing. Buy the pump, bottles  and oil tests on Amsoils web site. I have used Polaris labs.
Blackstone will give you basic wear and additive PPM data but you need GC fuels reading, KF water reading, and a full battery of FTIR data so the info can be interpreted properly for your application. Well done oil analysis with modern battery of tests interpreted by an experience analyst CAN ID most issues with modern engines.  Their centrifuged pentane insolubles is a good reading but not as good as FTIR data.  Combustion dynamic or gaseous cylinder/head/valve-train and piston interface is what you must read to find problems BEFORE they trash your engine.
GC fuels because flash testing is not good enough for polymer rich fuels additives chemistries.
Karl Fischer coulometric water titration because fuels additives specifically aldehydes, amines, and phenolics will build in fuel diluted oil.  These are also oil additives etc and the analyst must divine that.
I retired from 42 years of chem engineering focused on fuel and lubes formulating and engine transmission and gearbox R&D.
I will help here as I can but if you get weak data its better not to sample.  Bklabs folks are great but they NEED those additional tests for modern engines or you are guessing.
1/4 OD CLEAN tubing and depends on the dipstick slide guide whether you can access the oil, its amazing how many engines of same type have different slides attached.
I wish I was not retired or had to be.......there is a need for real science for the consumer.
Edited by customboss
The Blackstone pumps are identical to the Amsoil unit, just different stickers.
I found that the 1/4" tubing is too large for my 21 6.2 dip stick tube, called Blackstone about this and they sent some 1/8" tubing, works fine now.
I've use Blackstone Labs but prefer Oil Analyzers.    You can get the UOA kits on AMSOIL's site like stated above.   Also the suction pump and tubing.  I tried to put the tubing down my 2019's dipstick and it would not go.  I didn't want to try to hard and have a piece of plastic break off.  So I just use my Fumoto Valve I installed on my oil pan.
Edited by Black02Silverado
grammer
    • I had an issue with a new Z-28 some years ago. The 4WDB's were less than adequate when purchased IMO.  I had taken it in for small warranty services and asked them on three occasions to check them. Each time is was "could not duplicate on the service ticket. The warranty ran out about a month after my last visit and had to take it back for warranty rework. I again complained about the brakes. Well, low and behold, this time they determined the rear calipers were sticking and gave me a quote to repair. They had records as well as O had receipts of each time complained about the brakes while still under warranty. My dad was a life long body shop owner and told me to keep my cool and tell them that I wanted to speak to the GM Regional District Manager. The service manager disappeared for a few minutes, came back and told me they would replace the calipers free of charge.
    • Towing a 2022 Lance 24 ft travel trailer with our 2021 GMC Sierra 2500HD, gas.  Loaded, trailer is about 6,000 lb.  We get up to 10 mpg at 55 mpg, such as I-5.  Pleased with the combination.
    • I decided to give it a shot and see what sort of a gong show it would be to a pan drop themed oil change on my 2025 gas truck with the 10 speed. All indications I had seen so far was that there was no way that pan was coming out of there due to the cross over exhaust pipe not allowing enough clearance for the back end of the pan to duck out from under the valve body since it hangs lower than the pan to trans mount flange and certainly the filter does. I never touched any of the exhaust mount hardware at all, be that the engine manifolds to Y pipe, the bracket on the side of the transmission, or the two bolt flange further back behind the trans/transfer case. I put the truck up on four jack stands as there was no way I was going to struggle with that lack of clearance under the truck. The truck was cold as it had sat over night so all the trans fluid had drained to the pan, so I drained the bit of oil that would come out of the level check plug at the bottom near the front of the pan and put the plug back in to reduce the ensuing mess after that. Then took out all but one bolt front and rear and then pushed up on the pan and took out the remaining two bolts and then let the front of the pan tilt and spill out most of its contents into a drain pan. I then popped the pan gasket off its two locating nubs and kicked it a bit to the left side so it was no longer on the flange of the pan to get all the clearance I could and managed to get the pan slipped out of there by swinging the front of the pan to the right but keeping the rear part of the pan inline if not slightly to the left of its mounting flange area and lifting the front of the pan enough to keep the rear part of the pan low enough that allowed the pan to "JUST" slip out without forcing anything. I installed a new trans filter and seal and as per GM instructions on this site I torqued the two bolts to that 44 inch pound goal ( they take an 8 mm socket ) In reversing the pan procedure after I had cleaned up the pan both inside and out completely ( touching the outside of a dirty pan and dealing with installing a gasket at the same time would be a disaster ). First I slipped the pan into place and yes it took me a while as it won't go unless its slid in just at the right angles, then once the back of the pan was into the area of the flange mount, I went and got the gasket and then threaded that through the front of the pan and feeding it under the filter etc and finally working it onto the flange of the pan and lining up the two locating nubs to drop into the pan. Then lifted the pan up into place and get a couple of bolts started and check and make sure the gasket is where its supposed to be as the bolts were being put in. I never used any power tools as I don't have any of the whimsy little drive guns, I use what looks like a small screw driver handle with shank that has a 1/4 drive on the end of it and added an extension and those bolts use a 10 mm socket as some times power tools can bite a person if used on delicate parts ( torqued to 80 inch pounds ). Also should note as per rules around pulling the add plug out first, yes I cracked that loose with a 8 mm Allen bit socket on a 3/8 slim head ratchet as there isn't a lot of room to work with there either due to the exhaust on the right side of the trans.    I already had delco ULV oil on hand and of course the quart bottle pump wasn't made for those small cap threads so I had to use some other containers that the pump would fit and keep transferring oil over into them so a wasted exercise there but indeed the small pump did work just fine as ULV oil is thin and easy to pump in summer time weather. I put in 9.5 quarts as per prior minimum recommendation and yes that cut it pretty close as once I had the truck ( off the jack stands so its level ) and the trans oil up to 167f , about 6 ounces came out but a level kit or what have you could throw it off just enough that it wouldn't be enough oil so probably that 10 quarts is a good amount to put in so one doesn't have to add more oil as when its hot I sure wouldn't want to be adding oil so would have to let the exhaust cool. All I do for warming up the transmission is sit there with it in park and rev it to about 2500 rpm and it takes close to 20 minutes to get it up to that lower limit of 167f, weird how it will warm up more doing that then by driving it, I am not real keen on power braking the truck to get the temp up there and don't seem to have to either. By the way I only have 9000 miles on the truck so probably not a very good payback on doing it that soon and the magnets had such a minor thin layer of fines on them so that was good to see and the color of the oil was a darker red then new oil but still looked very good as it should and I've not done any towing with it so its been living a pretty easy life so far. The filter is made in such a way that its next to impossible to pull out the filter media but there certainly was some fines showing up there which makes sense give the trans having to break in.    I hadn't really planned on explaining this much of what I had done since there are various instruction videos kicking around or I think so, as the gist of my message as that by fluke or what have you, for some reason my truck has just enough clearance to slip the pan out from the trans. Of course there is no guarantee that other trucks like this in general will also allow the pan to be taken out without messing with the exhaust as I expect its probably a crap shoot if it will or won't, I was just happy to find out that mine would work and avoid all the other struggling and possibly damaging things in the process,
    • Do you fellas think Fog Lamps would  be a good upgrade for our 2024 2500 HD Custom ? As you probably know it did not come with them ,  Would you put in GM Chevy parts ? Do they get wired up to the switch panel ( Upfitter or whatever the correct terminology is ) on the dash ? Thanks
