Have a 2022 coming, so starting to look at floor mats.  No center console so thinking of mats that cover the hump.  I've usually had husky or weather tech, but saw on Chevy.com they have some that are 2 piece but interlock over the hump so if you need to dump them or take them out, little easier than 1 big piece.  Any thoughts?
I got the Chevy all weather mats with my truck and so far they've done really well. I liked them for the same reason, they cover the middle hump, which is nice when it's muddy out and I have one of my kids sitting in the middle. We tend to do a lot of outdoor activities that can get messy and it's nice being able to just pull out the mats, hose them off, and put them back in. They don't necessarily come out super easy due to the odd shape, I move the seats back to make it easier. The fitment of the mats is surprisingly well, they don't slide around, and have done well containing all the dirt and sand. Not sure about longevity on these mats, since I haven't had them even a year yet, but only time will tell. Not sure what other options are out there, since I liked the Chevy mats.
Ok, so now the question is....where is the best place to buy?  Shipping from chevy.com is crazy, same with a couple other places.  Where do you all get your parts for your trucks.
When I was working ROWs I would go to our local carpet store. They had carpet squares for display. They always had extras for a 1$ apiece. I used those for many years.
This^^^. Those are great, during calving season.
  • 3 weeks later...
The GM are virtually door jam to door jam, stopping just over the kick plate on each side.  No peaky lips or risers to trip over or hold water. Easily removable to hose off.
Ordered both a 15 and 16. They GM included matts.  It had been a few years since the last new one and everyone ws recommending the aftermarket liners.
Both trucks had console, so separate front pieces.
Now not sure which I tried first, but one got husky and the other got weather tech.
Wasn't happy with either.
Next truck was a 2018. Was convinced to try the GM liners.
Not sure when gm stepped up their game, but based on trying those 3, the current truck is also GM liners.
Was going to go with the GM but I received  Last Fit mats and they seem not to bad.   They fit pretty good, full coverage in the back,  I have a console so you will only get so much coverage in the front. I have to say not too bad but only time will tell.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,188 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
