Alright everyone,
First went for a drive and verified that i can see the DFM activate, which i saw. i am using an Autel MP808
i pulled over shut off the engine pulled fuse 60 and 67 and started the engine back up. no CEL, no codes in any other module. hit the main road and pulled my foot off the pedal(still light pedal to keep speed, noticed that the DFM was activating.  Pulling the fuses does NOT disable the DFM.
I **saw** that the hood status was on the DFM page, i pulled over popped the hood and verified that the hood was properly latched and continued, immediately the dash reminder came on(to tell you the hood is open) and DFM was still not disable.
Sorry guys i wish this would of worked. I wonder what those fuses actually do?
FYI i was that DFM is activated when you're off the petal and coasting it seems to default to pistons 1 &3.
Edited by BlancoSilverado
** added more info**
  • Like 4
4 hours ago, BlancoSilverado said:
Alright everyone,
I was that the hood status was on the DFM page, i pulled over popped the hood and verified that the hood was properly latched and continued, immediately the dash reminder came on(to tell you the hood is open) and DFM was still not disable.
Was really wishing it did the trick, but I guess that would be too easy. Thanks for verifying it.
Well let me throw this in there being the fuses are pulled the computer might be throwing the signal to activate the lifters thus seeing it on the scanner, but they are not being activated due to the fuses being pulled much like a light bulb removed from a socket, you turn the light switch on it sends the power to the socket but won't work due to no bulb. :dunno:
That's a really good point; the computer would still be sending the signal and the scan tool would pick it up, but there's no power to the solenoids (I assume) with the fuses pulled.
I know on our L84 5.3 truck with the 8-speed, DFM is painfully obvious if you maintain precisely 31 MPH on flat ground as that is prior to a transmission up shift point at 32 MPH (it sounds like a helicopter in the cab...). If someone with the same setup wanted to try this with and without fuses, that would be pretty conclusive for me.
I'm really tempted to try this myself, but I've already had four lifters replaced and I have extended component coverage on the engine as a result, so I'm a bit chicken to try anything that would potentially void that as I know it's going to happen again. This does have me hopeful, though, as it doesn't doesn't seem to set any codes when you pull the fuses, at least.
That is a really good point. What we really need to find out is what are those fuses powering? I don't have access to a wire diagram.
Ok, I tried it. Based on the fuel economy readings and tell-tale vibrations, DFM was still active in D with the fuses removed. I switched between L7 and D on a few low speed neighborhood roads and also cruised up to 65 MPH on the highway to try this out. Looks like I'm firmly in the "L7 for Life" club.
1 hour ago, Deadstockpomp said:
I started the thread on the trailboss forum. I just wish we can figure out what the fuses do. If it does not disable it then what is the purpose of them? It just makes no sense
Agreed, mine are still out.
Guys... I haven't really read any of this thread; but there's no fuse you can pull that will disable dfm. Dfm operation is controlled by the ecm, and can only be altered through tuning.
Added a Pulsar LT to disable mine.
Nice! I didn't know they managed to figure something out. But yes, that's still through tuning.
Interesting topic, shame this doesn't work. I have a Range OBD2 DFM disabler but for the first 5 to 10 miles it still allows DFM to activate which is annoying and not great for a cold engine.. I just leave my trans in L7 (8 speed) and keeps it from kicking on until i hit the 10ish mile mark on a drive. Once i hit around 10 miles or so I can put it in D and runs as it should on all 8 cylinders all the time... until i turn the truck off again then have to start the whole process over again. UGH
There is a lot of interesting information in this article. It explains that equipment/wiring/etc. for the DFM can be present, but if the vehicle has RPO YK9 (was built without DFM) the ECM can’t activate it.  I guess this explains why someone without DFM still has the fuses in the block.
https://gm-techlink.com/?p=14558
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 965 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
