So there is a thread about loud tires but I’m wondering about quiet tires.  I have my stock Bridgestone tires and they seem a pretty good balance between an all season tire and being quiet.  My guess is that my next set will be Michelins.  Not sure what model.  Any recommendations on a good, all season quiet tire?  Note that off road for me is parking on my lawn when there’s not enough room in my driveway so that’s not a consideration.
17 minutes ago, GA_RST said:
Nitto Ridge Grapplers ride just like the OEMs
Those look nice!  I’m surprised they’re quiet.  Definitely on the list!
What size tires are we talking about and what truck?
Michelin LTX M/S2 are a great tire. Quite and good rain/snow traction. Good life span too.
This is the tire that came OEM: Bridgestone Dueler HT D/684 255 70R17
125,000 miles of trouble free service which I thought were both quite and comfortable.
bs_dueler_ht_d684_ii_full.jpg?imwidth=440&impolicy=tow-pdp-main
These were even better:
PIRELLI SCORPION VERDE ALL SEASON PLUS II -
265/65R17
UTQG: 740 A A
Scorpion Verde™ All Season Plus II
My stock tires are 275/60/20’s and my truck is a stock ‘21 Denali (no lift or other suspension mods).
That is not an all season highway tire.
Fwiw, the 'all seasons' will be quieter than 'all terrains', which will be quieter than 'mud terrains'.
If you don't need all season or all terrain a 'highway' tire should be even quieter and provide better tire life.
I've been a Michelin LTX AT/2    ( there is also a new LTX MS )
https://www.michelin.ca/en/auto/browse-tires/by-category/light-truck
But haven't bought in a few years and always interested to hear what is new or what others are having success with.
Do not buy the Nitto Ridge Grappler if you see heavy amounts of snow and deal with ice on the roads. Just look at the tread pattern, they are garbage on anything icy. Trust me on that one, we sell a lot of them here and hear all the complaints because too many stupid people only care about how the tire looks and not how they perform when you need them to.
Michelin Defenders are going to be some of the best tires out there. Pirelli makes a nice tire too for an all season that is quiet.
Thanks, I’ll do my homework. I may even go to a summer/winter set up.  Got time and looking for advice.
Check out the Toyo AT/3's. They have done real well all around and are 3 peak rated for weather up here too.
Edited by Grover67
added
They do just fine on the highway.  Literally ride like stock.  I run these year round, however I do live in the south.  We recently had snow and ice and they did just fine.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
