$3.47 my location
$3.53 Denton, Tx
$3.09-$3.28  Lubbock Tx
In my part of Kansas 87 10%ethanol $3.45  Diesel $4.65
It sounds like we're Hormuzing for a few days, so I've got my eyes out for any price drops. It's such a traffic jam up in there right now, I wonder how much oil will actually make it through?
Prices haven't changed for me. Still holding at $4.19 for 87 and $6.29 for diesel.
$3.79 seems to be a popular price but lots of places are higher. Rumor is that 15% alcohol is coming soon. That is not good for anything I drive. Alcohol free fuel is not available anywhere within 50 miles
I've ran 88 octane in every car I've driven even if the car says E10 only, never made a single bit of difference. The car doesn't know the difference between maybe 10% or maybe 15% alcohol content. It's never really 15% anyway, every time I logged the alcohol content with HP tuners on my truck, it was maybe 12-13% at best, again doesn't even matter.
87 octane is $3.65 now.
My experience with 88. Is it's cheaper but you lose a couple mpg. My alcohol percentage we're pretty much the same as yours. I hit 14% a few times.
$4.30 85 oct. our small town.
$5.30 regular and diesel still hovering high $6's. Don't expect relief anytime soon...
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
