FYI, to use directions on the built in google maps, internet availability is needed.  So one can pay the subscription ($15/$25), or you can connect to the hotspot on your phone.  I had a chance to try it out yesterday, now that my free month of data is gone.  I don't use any of the streaming music services, so can't speak on that.  Assumption is streaming would work with hotspot also.
Yea, the phone mobile hotspots are sufficient enough to really not notice any downfall in the entire refreshed infotainment in regards to speed.
I don't have a 2022 refresh.. yet
Can you still use Android Auto and step around the built-in?
Edited by Rob Mugs
Yes it has wireless Android auto and car play capabilities.
Does the system have a built-in NAV system that does not require either a hotspot or data?  So in other words, to get NAV in any shape or form, it has to have wifi?  I know about Carplay/AA just wondering about what it comes delivered with.  If so, that's kind of crappy if you asked me.
No, the system is based around the Google Car platform. To use the Google Maps the truck has to have a data connection.
You can download offline maps at various map scales using your homes wifi before you leave on a trip. Or use your hotspot to set directions and Google maps should save the directions and general roads along the route in the temporary files folder.
This is all assuming the Google maps works completely the same as it does on all Android operating systems. So far as I have been using it, it is pretty much the same.
First off the truck is a data hog.  I picked it up May 4th and by May 17th the data was gone. The  weather was nice so I was riding my motorcycle and I had only actually drove the truck 4 times maybe.
I tried to hot spot it to my iPhone the truck will not even see the hot spot.
If you use offline maps they expire after 1 day and then vanish.
It's looking like it's all setup to force you to buy data.
If anyone hot spotted an iPhone to the thing Please let me know what you did to make it work. I even tried to manually enter the hotspot name/password and nothing.
Makes me mad I have unlimited data on my phone.
I would check to see what signal your hotspot is transmitting on. My guess is the refresh infotainment will only recognize 5 gHz transmissions and not the old 2.4 ghz Wi-Fi signal
Well I messed with the Compatibility setting and the truck now sees my IPhone.
But I have confirmed Hey Google and advanced Map features will only run off of the truck data plan. It actually bring up a message stating this.
So the only thing I've gained is google maps basic operation.
The truck will not even pass the speed limit over to the dash from maps.
I just (re) checked on my android phone .
Maps areas covering routes I have viewed in the last few days have automatically saved the regions in 'offline maps' have expiration dates that are a year away, not a day away.
I have no idea how long googlemaps stores them on an iphone -- it I'd guess they should be the same?
Is the maps on the right side where the clock is part of the data plan? Because mine vanished after a couple weeks??
Yes. The small map on the right requires the data plan to work.
  • 3 months later...
So I've red multiple threads regarding the functionality of the built-in Google Maps working or not working WITHOUT a data plan and some mention it flat out does nothing like inputting a location and getting directions to it and others say it works. If it is connected to a hotspot does the built-in Google Map capable of giving directions minus the "Advanced Feature - speed limit display and Hey Google"? Just trying to understand the design it was meant to be.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 721 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
