Does anyone use regular gas in their truck, if so what effect does it have?
Best case... Slight loss of power and decrease in fuel economy.  Worst case misfire.  Never tried it in my 20.... My 07 with a 6.2 hated anything but premium.
I've started blending. I usually fill up around a half tank all the time so now I will alternate between 93 and 87. If for some reason I run to a quarter tank or even below I'll fiil with 93.
93 or bust.  6.2 does not like anything less.
The engine is tuned/set up the to run on 91 octane. 93 is fine but not required..or spec'd in the manual.
This is because 93 octane is not readily available out west.  Most stations around me have 87/89/93 octane at the pump.  A couple have 87/89/91/93.  The 91 is usually less than $.10 difference, so I just use the 93.
Colorado 85/87/91 oct. 30+ cents a gallon for 87, 55-60 cents plus for premium.
With the exception of my current ride I tuned my trucks to run on premium for more performance. Paying extra for the 6.2 then putting regular gas in doesn’t compute in my little brain. I’ve heard on some car related programs that running regular gas in premium tuned engines causes no harm. They’ll just detune.
It'll pull timing so it doesn't knock (or at least to try and reduce the knock) --  which makes it unable to make the power you paid all the extra money to get.
Edited by redwngr
3 hours ago, CASEY7777 said:
Tried 87 and 93 octane, not hauling heavy loads. I get the same gas mileage with 87 or 91 octane.
Octane rating has nothing to do with the amount of 'energy per gallon'.
Only with how it burns .
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
