What are all your thoughts on the new ram charger? Basically an EV with a gas generator on board to power up the battery as needed.
Leaving aside the issue of Ram vs GM, I'm curious how you guys feel about the concept itself, ie: an EV with no range anxiety. More pulling power (well over 600  hp) for towing, a very low/heavy-ish center of gravity for better trailer control, no public charging needed, and when daily driving you just plug it in at night!
The devil is in the details though. Price is everything here, as well as implementation (like is it too complicated?). The generator used in this truck is the very popular 3.6 pentastar, though it is only wired into the generator and there is no physical connection to the drivetrain (unlike the volt).
I'm mildly optimistic. I want a v8 for many years, but if we're forced into EV's then this is the only truck I'd consider if the price can be kept in check.
Edited by the wanderer
Its like the Volt (not 100% the same but simliar) but in a pickup truck.  And the Volt idea was great.  Up to 50 miles of pure EV driving, you could recharge it, and if you needed to go past the just EV range the engine fires up as a generator but could if needed drive the wheels.  RamCharger however just uses the engine strictly as a generator.
So to me, a great product but its late to the game about 5-7 years.
Edited by newdude
I don't see how something can be late to the game when there is no direct competitor (no other EV truck has a generator onboard so they all suffer from range anxiety). The other standard EV's are still ramping up production in a market that is 95% untapped. We're all going to be pushed into EV's, yet nobody is driving them when it comes to trucks. Seems like this charger is being brought out right when it needs to be.
Late to the game = What they've come up with is pretty much the same idea GM came up with from 2010-2017, the Chevy Volt.  And if we want to get really technical, everyone does keep mentioning how the ICE engine in the Volt "drives the wheels" but at a fully depleted battery.  Its otherwise just a generator like the Ram.
Ram should have had this truck years ago, but FCA/Stellantis always seems broke.
Everyone seems to still be hung up on range anxiety, but its not range anxiety, its charge anxiety.  Silverado EV with the 450mi battery has potentially 450mi of total range.  Towing figure it cuts it 200mi.  For 99% of use cases, there is zero need for a range extender there.
And, the point of EVs coming out is do get away from fossil fuels, not add them into the mix for range extending.  Better batteries (less weight but more energy density), less rolling resistance (more aero) and lighter weight and more affordability are what is needed for EVs to really make them stick for 99% of consumers.
If you're going to carry an engine strictly for use as a generator, why not diesel? Wouldn't that make the complexity slightly less while improving the overall longevity of the engine?
For me, I'll never own any Dodge/Jeep product. There's something about their seat design that isn't compatible with my body. After about an hour behind the wheel, no matter the model, I am extremely sore. I travel for work and have issues with all kinds of Dodge/Jeep vehicles over the years plus I owned a Ram and a Jeep at one point in time - have never been comfortable driving them.
Because you don’t want that eco-diesel 😂
The concept of a gas engine generating electric power on board is not exactly new and exciting. That's how diesel trains have worked for decades, so this is not some earth shattering discovery on GM's part with the volt. This idea makes far more sense in a truck than a commuter car which just shuttles back and forth between home/work and can be kept charged overnight. A (work) truck can have other needs, like immense amounts of power and unpredictable destinations that change every day.
However that misses the point. This truck has no competition. By definition it can't be late to a game when it's the first one there. You can say that Ram should have had this years ago, but I don't see Ford or GM building one, do you?
And as for range/charge anxiety, you can call it what you will but the problem is the same: guys who regularly pull trailers will never buy a pure EV in the next 2 decades. The battery capacity is not there, the charge time is too slow, the chargers are too few and far between especially in rural areas, and that doesn't even get into the uglyness of charging where you block other spots or have to disconnect your trailer to fit into the tiny EV spot.
An onboard gas generator completely eliminates all this. It's really the best of both worlds.
Finally; as I said in the first post it'd be nice if we can stick to the idea (gas generator on board) vs the brand.
As for the diesel, no way you can fit a modern diesel into a small package like this along with the generator, battery, emissions, def etc etc. Diesel weighs significantly more as well making an already heaviest truck in the class even heavier.
If I was to buy an electric truck. I would put a generator in the back like my 1500$ stand by generator for my house. I would use rubber mounts have a bed cover run the exhaust to the truck exhaust. Easy plum job. I would open the bed cover fire up the generator. But of course the electric trucks are way too expensive, why bother?
Ok, I gave it a few minutes. There’s no exhaust on an electric truck.
  • Haha 1
I haven't read up on it but I'll certainly check it out when I'm ready to swap trucks. I've had about 8 Rsm/Dodge trucks. Last being a 2019 Ram Limited which was a great truck. I liked the air suspension and the interior was the best truck interior by far at the time. The GMC Denali Ultimate interior rivals the Ram Limited. If the Ram has the new Hurricane twin turbo straight 6 along with the hybrid electric drive I will really interested in it if offered in the Tungsten model. I had the F150 Powerboost.. That was fine till it broke. The dealers can't diag and/or fix them.
Let me understand this...
This truck has a full onboard ev system? Then it has a full onboard V6?
So you have the complexity of a EV and the complexity of a V6 in one truck.
Won't this V6 have to have emissions? O2 sensor, a cat, a gas tank and evap components for it, a charging system, a water pump, and cooling system.
Dodge, Mopar, Chrysler, Ram Stenatlas(sp) whatever it is today, needs to die and just go away.
https://www.ramtrucks.com/revolution/ram-1500-ramcharger.html
I think this is brilliant. EV running around town. Then load it up and take off for Florida. Able to drive straight thru with only one stop for gas (690 mile range). Hands free driving of some sort. Hopefully equal to Super Cruise. Best of both worlds. Doesn't have the Hurricane....the only con for me.
Edited by Jus Cruisin
So, we can put a diesel engine in a vehicle capable of pulling 80,000 pounds but we can't put an appropriately sized one in a pickup... to run a generator? A diesel engine, comparable in size and power output to what the V6 gas engine can do would add... a couple hundred pounds overall max?
We can have the diesel in the truck to directly operate the truck, but it won't fit if there's a generator added on. Which already adds more weight. There seems to be a lot of holes in this rationale.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
    • That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
