I was just wondering what pressures you all are running in your rear tires when not loaded. I was considering backing the rear down to 65 psig for a softer ride instead of the recommended 70 psig when not loaded.
I have a 2021 3500 cclb srw gas with 18” wheels and original stock Michelin tires, so the recommended rear tire pressure at full load is 80 psi. The rear TPMS alarm is at 62 psi. I run at 63 psi in the rears even when I have my light pop up truck camper installed (1800 lbs wet and loaded, 1700 of which is on the rear axle). I run 57 cold in the front. With the camper installed my front and rear axle weights are about equal.  My payload rating is 4054 lbs, so with the camper I’m at about 50% of payload. I’d run the rear at 55-57 unloaded if the TPMS warning didn’t go off.  My tire wear seems pretty even so far at 11,000 miles.
I tried running mine down around 50 in the rear and even with that, my tire shoulders are barely touching the ground if I do the chalk test.  And the TPMS whined.  You can apparently have the threshold of warning set lower.  I might do that.
Please post if you find out how to get that done. It was previously discussed as a possibility but nobody posted a way to actually do it. Thanks.
The one concern I can see about resetting the alarm point lower is that the alarm point is too low if you actually are fully loaded and therefore need to run at the max pressure.  If I was carrying 4000 lbs in the bed at highway speeds for a long run I’d want the alarm point where it is.
You can pay a GM dealer to do that for you, but some dealers refuse to do so because of potential safety liability issues. Or you can buy a pricey GM scanner/programmer that will allow you to change the TPS alarm thresholds as needed, amongst other things.
Edited by MaverickZ71
Thanks
I have an Autel TS508 that I use to relearn the TPMS sensors when I swap wheels/tires between summer and winter. The manual states that the tire pressures on the placard can be changed but I have not used that feature yet. When I get my AT4 HD, I’ll probably try that feature once I figure out what tire pressures give the smoothest ride with a cap on and all of crap I carry around in the truck and bed.
Running tires at the recommended pressures when not loaded just prematurely wears the tires. Usually, just the center. The only time I need max pressure is when pulling my tractor. Since I don't do that often, I don't care. The 1st thing I do when grabbing the tractor is checking all 8 tires truck/trailer. If you are worried about the tires going down with a load, turn on the tire screen. You can see my new settings on the pic. They crossed the front and rear numbers.
One of the reasons I'll be buying the Pulsar LT when I change sizes is it's reported ability to change the alarm point. I'm currently getting texts, emails, and truck yelling at me about one of them at 64. I would probably run about 50-55 on the Nittos when I get them. I haul mostly sail boat fuel and don't need to be aired up so ridiculously all the time.
As to OPs original question.  I have been running 58 ft / 55 rr in my 2500 for 25000 miles.  Air them up to 60 and 70 when towing the RV.  No unusual wear.  Do get the occasional TPMS warning on the rear on cold mornings etc.
I have the 20 wheels and the OEM Goodyear Trailrunners.
Happy trucking!
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
