Horsepower is always there if you can free up air in/out. Will this add anything to a stock truck? Maybe ~5rwhp under the right conditions. When it would absolutely become a great supporting mod is after adding full exhaust and a tune, or especially with a cam/heads....etc. The stock L8T setup already gets great ambient intake air temperatures (which is crucial for max timing/power in modern ECU controlled engines). This mod will just insure that it continues to under more conditions and again, become a supporting mod for other added power items. An LT2 cam, ported intake/TB, 2" headers with true duals, or just a good ol fashioned blower.... all that stuff isn't off the table and might some day be in the cards. This intake will compliment stuff like that nicely.
I set out to buy and build the best possible truck I could to be my last truck I'll need. Getting rid of the fake vent for a true factory cold air intake system for under $700 fits that mold nicely.
The last piece (front intake tube) finally got through processing and is being shipped out. Full parts list and all that jazz soon to come.
Edited by Epsilon Plus
Air box lid is going to need some wizardry. The plastic tray thingy on the battery needs to be shaved or the battery moved back towards the firewall 1/4" (might be able to loosen mounts and shift it). Diesel must have either a narrower battery or different top tray. Larger issue is the front of the lid interference with the front transmission cooling line. Diesel likely has a different entry point or something. A Dremel to the outter casting webs of the lid may take care of it or else something more drastic is needed. Unfortunately, I'm very limited on time to play with it right now and it's also the middle of Arizona summer so I'm going to shelve this for awhile. Maybe an S&B box might fit better there but at those prices I'm not going to be the guinea pig just yet. Everything else dropped right in. Only the lid and it's aggressive casting material webbing is the road block now.
If anyone is interested I replaced the chrome one on my 2022 duramax with a black one for personal preference.  It is in like new condition.  Maybe 500 miles on it before I swapped it out.
What you see is what you get.
$65 shipped
Top down shot of the straw that broke the camels back on this mod.
From pics online, diesel doesn't have a cooling pipe in that spot. Unless the S&B or Banks is somehow smaller or misses that area (doesn't look like it from pictures), this mod is officially dead. Can't move the box back because of the battery and needing to line up with the hood. Unfortunately, even with all that massive room under the hood, this particular space is tighter than a frog's ass.
Sometimes you win, sometimes you lose. RIP L8T hood mod.
  • Sad 1
Don't buy the S&B for testing, it won't fit. I can go out and take a picture if'n you like.
The S&B and Banks both look bigger than stock so not surprised. Thanks though.
I'll probably try modding the top of the lid and playing with some plastic moulding/welding since I'm stubborn and like to tinker. Unfortunately, even if I get it to work it won't be a plug and play drop in mod for everyone else like I was hoping it was. My buddy has a 3D printer......hmmmm lol
Just throwing this out there - we have local O'Reiiley's auto parts that can build/make steel hydraulic lines. I wonder if it would be easier/cheaper to see if you can have a different shaped coolant line made? Just spitballing ideas, not sure if this would work or not
I thought about doing a 90° AN fitting and a braided line.
Turns out, I think that's an engine oil cooler line.
I had that thought...to take the box from the diesel sb intake...i have the gas one and  is very close to oil and trans lines
Edited by SKEETER1978
On 7/11/2024 at 1:48 PM, SKEETER1978 said:
What might work is making/3d printing a custom lid for the sb filter gas intake to attach to scoop intake
I have also thought about cutting the hood inlet pieces off the diesel box and bonding them to the gas box.
Even if the S&B diesel box fit, it has a hard duct to the throttle body that is in a different position than the L8T. The stock setup uses a flexible bellows that attaches right at the lid and makes the swap easy. However, if the box did fit making a custom TB connection and eliminating the Hemholtz resonator would probably be easier than dealing with the oil line.
My buddy has a 3D printer but I dunno the first thing about them or how technical it would be to recreate the lid with a lower frontal area.
There's a small chance the Banks would work. It looks like it dives down right where the oil line would be. I'd need a closer picture, especially from a horizontal angle if anyone has one. If the point of that box sits lower than where the line would be, we could have an option. Additionally, the Banks would be easer to adapt to the L8T throttle body since it has a short fixed pipe and goes right to flexible bellows. Would be a decent mod to have that box and get rid of the stock Helmholtz resonator in the process.
A commentt after someone mentioned the duct work being more of a ram air set up than a cold air intake. With the diesel having a turbo, wouldn't that negate any ram air effect? Ram air might be more effective on a naturally aspirated gasser.
On the GMT400, I remember the air cleaner being connected via duct work to the RH side inner fender panel to draw air from outside.
Also about separate diesel and gasser hoods, the two models of K2XX trucks had specific hoods...
True "ram air" would require jet engine velocities. Automobile engines are large vacuum pumps. They will draw in what they need from wherever you put the inlet. The only purpose for external (outside the engine bay) feeding is for lowering air intake temperatures which for this platform is negligible since stock is so good. The functional hood on the Duramax is mostly a marketing gimmick mixed with another way to increase air volume without redesigning the cowl and tight front air box area. L8T gas won't benefit from this mod unless it's got a blower on it or pushing over 600HP IMO.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
