Yes and no. Should the engine be using oil between changes, no not really but lots of engines do and that is pretty normal across all makes and models.
Seeing 1 Liter of oil usage in 6,000 miles is very minimal. Well within spec of what GM says is normal oil usage. You'll just need to get better at checking your oil more often to make sure it stays the same.
GM won't do anything about until you are using like 1 quart every 1,000 miles or something crazy like that.
5 hours ago, Forest City Computers said:
Good afternoon,
Just got an oil change on my 2021 GMC Sierra 1500 2.7T and the tech told me I was down about 1L, Im using Mobile 1 Full synthetic and I do my oil changes at 6000k.  is this normal?
Normal? No. Common? Oh yea.
6 hours ago, Forest City Computers said:
Good afternoon,
Not normal. How many miles on your truck?
Just think, if he changed his oil at 4,000 miles or 5,000 miles this thread would never exist because the oil level wouldn't be as low. But at 6,000 miles it's down 1 liter.
Maybe just change the oil sooner. Was it normal for my 6.7 Cummins work truck to burn 1 gallon of oil in 20,000 miles, probably not but when the service contract says 20k oil changes, not much I can do. The oil is like water at 15,000+ miles, so I just add oil to make it not blow up.
I just don't get people not checking their oil and keeping it full. My guess is if your cell phone doesn't  tell you to?
  • Haha 1
Shocking that so many people who depend so much on their vehicles will not put the least little effort to keep it from blowing up.
16 hours ago, Forest City Computers said:
Good afternoon,
Totally anecdotal and unscientific but my niece used to have an equinox with an Ecotec NA engine that used oil running M1. I told my brother to switch it to another brand and for some reason it burned much less oil on Pennzoil. He was surprised and I seemed like I knew something, a win-win    LOL
  • Haha 1
I haven’t had but 2 oil users since the 90s. Even those two would go to 5 to 7K oil changes without getting too low. With all the sensors on new vehicles. There isn’t one for low oil, like say two quarts?
17 hours ago, Forest City Computers said:
Good afternoon,
Sadly yes. Drive it in manual mode L7 highest gear and it’ll run all 4 cylinders stopping the center unfired  2 cylinders from forming a low pressure suck zone for oil drawing into PCV CCV system, when running in 8th speed or D.
Mine is a 2022.5, 25,000mi so far.  I lose 1/2-1 quart in 3000mi.
This is due to a leak that I still haven't bothered to have addressed 🤠    Either the lower oil pan or the oil cooler.  I do see the cooler wet at the bottom and half way up it, so my bet is the cooler.
Assuming I fixed the leak, I'd bet I lose 0-1/2 a quart in 3000mi.  I drive mostly in manual mode (L7 occasionally otherwise L8), and I'm not easy on the skinny pedal at times either.  Did my first drain at 1500mi after my own "break in" which is first 500mi normal driving, keep it no more than 3000rpm, 501-1000mi get it to about 4500rpm and some gradual load increase, and then the last 500mi get the RPMs up higher, load up harder and by the end a few back to back WOT pulls.
  • Thanks 2
Get ur damn leak fixed! Heal thyself Dr!!!
Too bad you didnt know a guy that could fix it for you  😉
  • Haha 1
Too busy fixing everyone else's problems?
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
