Hello all,
I have a 2013 gmc sierra 1500 with 55k. I want to disable the afm/dfm. Then I started looking at removal kits that have cams, lifter ect.
I am asking if anyone have done it and what brands are the best
Thanks
Anything from Texas Speed or Brian Tooley Racing. Those both have kits available and both are good companies to use.
I highly suggest just a stock non DoD camshaft if you want a hassle free experience that only requires tuning to shut off the DoD system and all of the check engine codes that go along with it.
If you put in a larger camshaft than stock, you'll need a custom tune done by a shop and hopefully they know what they are doing.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
    • I get it, Bad Bunny is huge but not everyone knows him The generational gap in music taste is real At least the show will be lively
