8 minutes ago, Atlas said:
It's still a German car / German company.
Kash had a number of US brands to choose from, including those who build cars I stated above right here in the US, by US workers.
What exactly are you defending here?
 11,000+ US workers employed in the US by BMW/BMW North America.
By your rate, should we also go cold turkey on all aircraft made by Airbus?  And take 7,000+ US employees out of a job, a large majority at the A220/A320 factory in Alabama, and then lose out on the $15 BILLION Airbus pump into over 2,000 US based suppliers in 40 states that supports 275,000 US jobs as well?
To quote yourself:     " I'm America-first on these kinds of issues and it's sad that we're straying from our own US companies when purchasing things as simple as transportation."
BMW and Airbus seem very "America First" with how much money they pump into the US, and the jobs they've created and still have and keep adding to.  I don't see a reason to not support them as well as it supports...THE UNITED STATES OF AMERICA.
Edited by newdude
6 hours ago, KARNUT said:
I guess you missed exports are up. You really need to relax a bit. So far your gripes are unfounded. TDS
I will admit, I had to pay the import fee on a product I purchased from a company in Canada. It wasn't cheap either, about a third of the cost of the product I purchased.
This is true of course. With price parity the product could be made here. More U.S workers more volume prices drop. In the meantime the other side screams the prices are up ignoring eventually more Americans will have jobs. More American buyers prices drop by volume. And so on.
For FBI vehicles I think we should buy American, US brands which do more business than BMW here and also build here.
But what about, but what about, but what about. Of course I wish government contracts would have gone to Boeing instead of Airbus. Same reason.
This is picking fly poop out of horse poop, though. I'm not surprised by the lot of pedo-sympathizers just rolling over on this. Sick!
  • Thanks 1
Unfortunately, this company seems to be the only one that has tried and true products for the Ecodiesel. They come highly recommended. It would be nice to have an American company come on board, but since the Ecodiesel is no longer in production, it doesn't make sense to ramp up a company to produce a product for something that isn't going to be around for a long time.  Sad, because it finally on the 3rd gen version turned out to be a great engine.
Canadian Club worth it! 🤣✊
Your assertion isn't supported by consumer price data or real world prices we're paying for things in America. It's just not. CPI continues to rise.
Americans had jobs, with under 4% unemployment, a pretty good number. Sadly, unemployment is going up, and fewer Americans have jobs this year.
  • Thanks 1
Sad NASTY SAD and Stan and his ilk ask for more.
  • txab locked this topic
  • txab unlocked this topic
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
