hooked onto my camper for the first time with the new truck. Its 35ft long and weighs around 7900lb dry. The L5P hardly notices it behind! I just put on a set of air lift bags in the rear and a new set of rims and tires since this pic. Can't wait to go camping
Yes, camping takes on a whole new meaning with these trailers!  We're heading to your province in a couple of weeks and have been looking at Blackstrap and/or Pike Lake.
went and picked up another project to work on...
D0180DAA-EB6B-47DC-BDD4-9058887A1FA2_zps
Does pretty good.
Sent from my Pixel XL using Tapatalk
Morning after pulling it from storage.
I’ll definitely be posting my boat and truck pictures once I pull the trigger at the dealership this week. The only one I have now is my Tacoma with my boat [emoji23]. Don’t worry though, because I sold it.
Just returned from a trip to West Virginia.. holy twisty and steep grades! We had a great trip and the Sierra was a champ. Almost forgot to take a pic of the rig: ec9e8e4096ca351dc980cefad7b5f108.jpg
First haul in the new truck. I pulled and stopped great. But dang did going over bumps or bridges rock the life out of you. It was like riding a boat it was bucking so much. Definitely going to be replacing those rancho shocks before the end of the year.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,121 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
