hooked onto my camper for the first time with the new truck. Its 35ft long and weighs around 7900lb dry. The L5P hardly notices it behind! I just put on a set of air lift bags in the rear and a new set of rims and tires since this pic. Can't wait to go camping
Yes, camping takes on a whole new meaning with these trailers!  We're heading to your province in a couple of weeks and have been looking at Blackstrap and/or Pike Lake.
went and picked up another project to work on...
D0180DAA-EB6B-47DC-BDD4-9058887A1FA2_zps
Does pretty good.
Sent from my Pixel XL using Tapatalk
Morning after pulling it from storage.
I’ll definitely be posting my boat and truck pictures once I pull the trigger at the dealership this week. The only one I have now is my Tacoma with my boat [emoji23]. Don’t worry though, because I sold it.
Just returned from a trip to West Virginia.. holy twisty and steep grades! We had a great trip and the Sierra was a champ. Almost forgot to take a pic of the rig: ec9e8e4096ca351dc980cefad7b5f108.jpg
First haul in the new truck. I pulled and stopped great. But dang did going over bumps or bridges rock the life out of you. It was like riding a boat it was bucking so much. Definitely going to be replacing those rancho shocks before the end of the year.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 292 Guests (See full list)
