I dug through the garage today. Looks like I'll be making a desk chair with one of my 02 suburban seats
Sent from my DROID RAZR using Xparent Red Tapatalk 2
i still want to do that! but the racecars ive had the seats didnt work out for me
i drove to muskegon and bought an iphone 4s.. was feelin fancy today
Just make adapter brackets with flat bar I'm taking the lower frame off and mounting to the upper frame that way there is no electronics down there
Wire for my Big 3 came in
Ran it through a fence and massive ditch going 50 mph and took out several tree's in the process. Truck was dented all to hell on the driver side. But it still runs like a champ and tracks straight, you can't kill a Chevrolet!
That sounds fun lol
Story of my life!!
my cousin would argue that fact lol
Holy cow Scott. If your cousin is still around to argue that fact it speaks volumes about our trucks.
Chawkins, I'd do a DC converter or motorcycle battery for the new desk chair, that'd be too cool.
Ryan, the wheels turned out sweet. Iowa is looking at 71 degrees and sunny on Saturday, if you get close to that in Indiana, I'd suggest one more day of driving around topless in the cammed arrow.
Waiting to get my rear blocks from ups and got 2 maxxis buckshots in great shape just need two more and ill finally have this old thing the way I want it for the most part
Sent from my SAMSUNG-SGH-I927 using Tapatalk 2
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
