I'm waiting to get my truck back. I hate my rental Altima. I get my truck back tomorrow. Can't wait
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Got the MIT in the truck...
In the Back seat that is. :lol:
Going to visit a friend tomorrow so I can do it in his shop. Technically not allowed to work on vehicles in my apartment complex.
finished this crap today... not impressed with the brightness need to upgrade the bulbs to insane whiteness
Got my truck back. I can feel a huge difference. 325 to the wheels. I'm happy
Oil change in progress
Then Dee zee tailgate lift assist going in
Ryan
So dim you couldn't see the no parking sign? :lol:
Drove to the Post Office with the exhaust I've been trying to sell so I could send it off to its new owner....bittersweet I guess.
Ryan
Ryan, I have that same Purdue window decal on my OUTLOOK and a similar one on the GMC :)
Cool. I think this yr I am switching my camaro license plate to a Purdue one.
Ryan
Placed my order today for 5W cree back-up lights. Of course my 2010 has the 921 bulb which seems to be half the size of the other.
Hope the lighting is still good.
Went and cruised down to get some food at 2 AM. It was wet, so I made sure to decimate the tires. Made my buddy crap himself I think. :lol:
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
