Chillin
Sent from your truck via Tapatalk
Just worn out or admiring your new rubber?
Drove the truck to work then drove around in the Mercedes for the day. I had forgotten why I hated that car until I had to open the gate. Then finished out the day in my truck. I love the new tune
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Well tires are on. Less than thrilled with the shop though- one wheel has three little weights instead of a large one and there is gauging in one wheel that I'm pretty sure was not there before. Live and learn, I should've inspected the truck before and after I guess.
Any reason why they didn't put the weights on the inside of the rim?
Too late now. They're on the outside. I don't care when it's done right but this was a hack job. Not happy considering I spent nearly a grand all said and done.
Spent several hours with this stuff:
Only to have the truck trapped inside of the garage due to rain. But that's okay...the truck rarely leaves there. I did want to get some better quality shots though.
Crappy iPhone 5 pics:
My 4.8 let go a head gasket at just over 100k so start saving
as much as i dont like the 4.8, yours losing a head gasket at 100k was a freak thing. they are reliable engines..
I'm trying.to decide which car I'll use to.take past my personal high of 260k miles. But so far we have driven the Tahoe 2300 miles since October. So probably won't be it, lol.
your corolla will make it past 260.. they are bulletproof
Lol @ freak thing! My head gaskets are the freaks! Stock still btw :lol:
Sent from my SGH-I927 using Tapatalk 2
Your crappy iPhone pics sure look nice. I did the same,but that was a couple of hours ago. Thank goodness for California car dusters.
Yeah it does okay, but I hate chopped off shots...which was the best I could do ATM. My paint was in serious need of correction and I think I did a decent job and giving some life back to it.
Well issues with the way the hacks used wheel weights aside, I do like the AT3s so far. Ride smoother than the lousy OE Bridgestones ever did and they seem quieter too. Obviously it'll be a while before they get a winter test (I hope at least!) as the only other thing I have planned is the dunes in June and tires don't matter much for most vehicles. My first time there in 2008 I rode with a friend who had BFG M/Ts that may as well of been slicks and he went everywhere. Including up Test in reverse. :lol:
275s are a snug fit, makes me wonder if they'll rub offroad. This is about 3/4 lock:
B026CA78-A07E-4722-BD67-7BDF6D49C38A-241
Don't blame the tires mike, we all know it was the driver :lol:
Ryan
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
