Actually Costco fuel is now considered top tier. But the thing is, I've found that they are no cheaper then most of the local Shell, Connoco, and Philips 66 stations. Plus I get a 10 cent a gallon discount using Shell with the Kroger rewards card system they have here.
http://www.toptiergas.com/retailers.html
How does that even happen? Someone only replace half of the pads last time? Someone saw two in the box and put one on each side?
Probably frozen slide pins.
I was also thinking that but they seem to be well greased and slide easily. Bossman told me to put new calipers on so we don't have to take it off the road again. Comes with new slide pins as well, and the calipers are relatively cheap $30 a side
Sent while cruising down a back road...
Took her for a drive to Sonic while the wife was at an appointment. She was averaging 17.2mpg on the tank which I wasn't minding with gas up at $3.95 now.
Threw an evap code and a P0154, not sure what that is. O2 sensor maybe?
LMGTFY: P0154 - 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
Sent from my Nexus 5 using Tapatalk
Yep my Insight pulled it up as "21O2 sensor no activity" or something. My understanding is that it's the passenger side ahead of the cat.
That would be correct sir.
I kept getting codes for all my o2 sensors. Replaced them all with Denso and none have come back. Don't buy Bosch!! They make good tools but that's where it stops. I was also having problems with their spark plugs
Put my new cv shafts in. I love that I can fix this thing myself and only have to dish out money for parts. [emoji12]
sent from my truck in a field
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
