I installed my new Alternator from DC Power Engineering, a fuse, and most of my 'Big Three' wiring. I'll add two more 0-gauge wires when when I get the new double-din DVD head and amp next month.
I was thinking you went with the spx line
Cleaning baby stuff out. Taking it to a nearby GMC dealer tomorrow to figure out what happened to the lights on it, front drivers DRL stopped working, the back pass side lower brake light won't light when brakes are on, both drivers side brake lights won't turn on. I installed a few new bulbs, checked the fuses, all are good.
Crap, all I did was disconnect some wiring harnesses, reconnect them, check some relays and fuses and replace the battery a few weeks ago when the electronics were going crazy(battery was dying). I noticed the lights yesterday when my wife was driving and I was following.
If this costs a lot I'm taking it as a warning sign to replace it. Which stinks because I love it.
Edited by SnakeEyes
Looks great! I need to do the big 3.
Thanks.
I forgot to mention that I also installed a Diehard Platinum to complete the chain, 850 CCA. (I believe the Diehard AGM units are manufactured by Odyssey.)
That is their 'OEM' 185a. (My stock unit was 140a max, ~ 65a at idle.) That should be enough to support a 200w amp and a few extra fog lights, a GPS unit , and A/C together without any lights dimming.
I plan to get a Pioneer AVH-4000NEX and a Pioneer PRS-D800 (125w x 2) next month. That should be a large improvement in functionality and tonal accuracy, with little more 'punch' in the bass compared to the stock 17w(?) unit. I no longer like to 'rattle the windows.' I listen to mainly jazz and classical, occasionally a little Steely Dan or Jackson Browne.
Edited by Singer-Man
I will probably go with an Alpine nav unit next year. The Pioneers are made to work with apple products. I need to find something to work well with android. Also with the AVH unit, you can add nav later. I never did but it is an option
Thanks.
If I get more lights I will need to do the big 3 and bigger alternator. 2 100 watt Hellas draw pretty heavy. :lol:
What was it in the end? Sounded like a nightmare.
One filament in each of 3 different dual filament bulbs had gone out within a few uses.
Well finally did it... I actually spent some quality time & vacuumed out my truck. Also checked my driveline fluids & mechanicals. I'm starting to get a roaring type sound on deceleration & wanted to make sure it wasn't something stupid obvious, nothing yet. Could be the tires, they have 21k miles, but we'll see.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
